Re: AAR, Gran Coupe Chrome Grill Inserts
[Re: AAR#2]
#1622807
05/21/14 02:20 PM
05/21/14 02:20 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
That may be, but been so disappointed with parts (not theirs, in general) in the past I usually try to refinish everything. I did call BE&A and he said his are triple chrome, price is comparable to having Pauls Chrome Plating redo my originals. . . if triple chrome is correct for the part.
Call me crazy but its nice having as much original as I can.
I hear what you're saying...But another point to touch on is how some of the detail is lost when you send original parts out to be refinished/replated no matter how good their reputations are...The excuses and back-peddling is all too common when the stuff does'nt turn out as it should be....Although in this case there really should'nt be any major issues with a simple,plastic rectangle other than the mounting tabs staying intact...
If you go the replating route please post the results I'd like to see how they turned out...
[Re: DAYCLONA]
#1622809
05/21/14 11:35 PM
05/21/14 11:35 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
IMHO, your better off using the BEAParts, but if you want a plater that can reproduce actual copper/ chrome plating that was done on assorted plastic pcs by/for the major automotive manufactures during the 70's, Advance Plating in Nashville Tenn. Steve and his wife run nothing but a custom plating shop geared for the motorhead/biker, every facet of plating is offered.....but you will pay dearly, but their work is top rate, no monkey business
I contacted them about two months ago on this very topic and they told me they don't do chrome on plastic, so with your post I checked their web page and its listed under new services. I'll try contacting them again tomorrow.
[Re: AAR#2]
#1622810
05/22/14 05:33 PM
05/22/14 05:33 PM
AAR#2
Dry Heat AZ
Looks like their out, sent in a request and here's a portion of the response; "We can plate some plastic but not all plastics. We will not be able to plate these parts. With our process they would most likely warp"
[Re: AAR#2]
#1622811
05/22/14 06:07 PM
05/22/14 06:07 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Initially that's why I said you were better off with the BEAParts, a lot of original parts that are chromed as they age go thru a chemical change, I bring a lot of parts to platers, and on occasions they ask me if I can get the part(s) repro or NOS, as they won't offer a guarantee that the parts won't warp or dissolve (esp old potmetal pcs) and they don't want no when they tell you your parts are junk or gone after being stripped electrochemically or during a re plating process, so either NOS or BEAParts seems to be your choice, either that or gamble your "original" parts with another plater, vacuumized aluminum "chrome" is a very non destructive process, but for an external part, it's not practical for long term durability
