Gas gauge problem
#1622545
05/20/14 01:00 PM
05/20/14 01:00 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
My son recently bought a '69 Dart and we are having a problem with the gas gauge working intermittently. We checked the sending unit ground strap and power connection and cleaned all the contact areas, but the gauge still periodically quits working for anywhere from a minute to a few hours. Can't find any pattern to when it quits working. I'm pretty sure it is an electrical problem so I realize it could be anywhere in the circuit, but I was wondering if there were any common areas where problems occur that I should be checking.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Gas gauge problem
[Re: MadMatt]
#1622549
05/20/14 04:28 PM
05/20/14 04:28 PM
Posts: 5,445 So Cal
Sinitro
So Cal
EZ to test... Just put a short jumper lead between sending unit & ground @ the tank. The fuel guage should read FULL, now drive around awhile if it stays @ FULL... Then everything forward is OK, likely problem is the sending unit either is intermittant and/or bad ground circuit.
If the guage drop backs to EMPTY then the problem is up front and/or wire back to the sending unit.
Just my $0.05...
[Re: Sinitro]
#1622550
05/20/14 05:42 PM
05/20/14 05:42 PM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
Just my $0.05...
Running a zero resistance ground to the gauge for an extended period of time may damage the gauge
[Re: TJP]
#1622551
05/20/14 06:58 PM
05/20/14 06:58 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
It wont maybe damage it it will damage it.That test is just to check to see if the gauge moves.I run a wire from the semder right to the body.Ive seen too many of the straps lose their grip on the outlet.One piece of wire one small hose clamp and a screw.Then you know its grounded.My 57 would do the same thing.The wire fixed it.Rocky
Chrysler Firepower
[Re: therocks]
#1622552
05/20/14 08:21 PM
05/20/14 08:21 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
Does the Temp gauge crap out at the same time? If it does, then I would check the cluster voltage regulator.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: RapidRobert]
#1622554
05/20/14 11:04 PM
05/20/14 11:04 PM
therocks
Niles , Ohio
RR Ive tested them and none go to a 0 ohm reading which a neg to body is.Typically the float is maxed in its travel and thats why the tanks usually stay full for a while.But if you want to ground the sender wire and drive around Good Luck.Rocky
Chrysler Firepower
[Re: RapidRobert]
#1622555
05/21/14 12:07 AM
05/21/14 12:07 AM
TJP
Omaha Ne
Just my $0.05...
The sender rheostat is dead shorted to ground when the tank is fairly full as the gas is above the sender windings which is why the gauge is pegged for awhile when you fill the tank & does not budge for awhile till the fuel level drops below the windings after so many miles then the gas gauge starts to move toward E as the float lowers and the windings are no longer submerged.
BS, not a dead short, think 10 ohms for a full or HIGH reading, a dead short for an extended period will over current the gauge and roast its windings or tweak the calibration. See the FSM for the correct readings
[Re: TJP]
#1622556
05/21/14 12:42 AM
05/21/14 12:42 AM
RapidRobert
Next time I fill up I'll ohm the threaded nipple & see if it's zero. yes ~10 ohms or so if the windings ain't submerged. I could be wrong on this and I will check
[Re: RapidRobert]
#1622557
05/21/14 04:29 AM
05/21/14 04:29 AM
Posts: 5,445 So Cal
Sinitro
So Cal
Many have jumped in... Commenting about the overcurrent... The point of the temporary ground wire is just that temporary... So that entire electrical circuit to the gas guage can be isolated, to see if the problem is up front or in the back.. Check it out... And then remove the temporary ground wire, having it connected for an hour will not hurt or overcurrent any part of the system.. Just my $0.05...
