Help identifiying Hemi heads. Stage 2's #1621452
05/18/14 12:28 AM
05/18/14 12:28 AM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Was wondering if anyone can shed any light on some Hemi heads my brother bought from Direct Connection years ago. The part number for the heads are 4007855. All he remembers is they are stage II's. He wants to list them for sale and doesn't know the particulars. Any help will be appreciated!
Re: Help identifiying Hemi heads. Stage 2's [Re: tcat446] #1621453
05/18/14 12:32 PM
05/18/14 12:32 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have a DC book, 1977, that shows a hemi head, part # P4007665, but it doesn't give any description of it.
You sure that is the right number you listed? Not saying it isn't right, just wondering if there is a chance it is this number. although that doesn't help either.
Someone will answer you, some of these guys will know.
Re: Help identifiying Hemi heads. Stage 2's [Re: Dodgeguy101] #1621454
05/18/14 11:19 PM
05/18/14 11:19 PM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
They are dual plug heads. They're aluminum and accept the bigger rocker assemblies and it has an extra head bolt hole on each end of the head but its not used on the regular blocks and KB blocks. Try to supply pics later. Thanks. Part number reads stage II P/4007855 just to be clear.
Re: Help identifiying Hemi heads. Stage 2's [Re: tcat446] #1621455
05/19/14 02:20 AM
05/19/14 02:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is that number on the box or the number on the head ? The number on the head is the casting number and is not the same as the part number.
Re: Help identifiying Hemi heads. Stage 2's [Re: JohnRR] #1621456
05/19/14 08:46 AM
05/19/14 08:46 AM
N.Y.
aardvark Offline
aardvark  Offline
N.Y.
That number is cast into the head right under where the rocker assy sits....only 1 head has it though.Don't see any other casting type #'s..as I recall...these heads were listed in an old 70's DC catalog with that P/4007855 part #....and the head description.I'm missing a few of those old catalogs so I couldn't check them all.Heads are being pressure checked now but when I get them back I'll give more info.
Re: Help identifiying Hemi heads. Stage 2's [Re: aardvark] #1621457
05/19/14 12:05 PM
05/19/14 12:05 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
It is listed in 1979 Direct Connection catalog as P4007855 Aluminum Stage II.
No other description. I will keep looking.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Help identifiying Hemi heads. Stage 2's [Re: aardvark] #1621458
05/25/14 05:40 PM
05/25/14 05:40 PM
Sweden
B5HEMI Offline
B5HEMI  Offline
Sweden
I've also got a set with that casting# on just one of the heads. Mine are Stage V heads.
Says STEL and STAGE V and has a cast pentastar on the right side of the casting#.
The other one says STAGE V and HANSEN.
