Re: Whats left of a 8 3/4 aluminum center
[Re: Bill_LBSR]
#1620890
05/17/14 10:29 AM
05/17/14 10:29 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Cool, can't wait to blow mine up.
'71 Duster '72 Challenger '17 Ram 1500
[Re: justinp61]
#1620893
05/17/14 11:21 AM
05/17/14 11:21 AM
RMCHRGR
Spahn Ranch
Probably not worth the expense. The aluminum cases have gone way up. I bought mine about 10-12 years ago when they first came out. I think it was around $600-700? Can't remember exactly. Mancini wants $1,100 for it now. I have a Victory billet 7290 yoke they want $160 for. That was also way less too, maybe $100-125? Mine has an Auburn sure grip ($400? back then maybe, now about $500?) and Strange Pro Street gears, maybe $175? Plus the bearing kit and seals, usually around $125+ for Timken. I built it myself, so no labor involved for me. But, I have the T&D pinion setup tool which is really expensive, like $400. It works great though, the generic pinion depth tools are not so good. Also have the adjuster spanner from Randy's and a Miller yoke holder. I was a tech up until about a year and a half ago so I used some of the tools at work but never used the pinion tool. Hard to justify that one.
[Re: Guitar Jones]
#1620896
05/17/14 11:59 AM
05/17/14 11:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I still have my alum center.... I have 1 question for the OP... did both caps have full threads in them... I know of a few that were sold that had very shallow threads in one side or the other
Three of those bolts are through the case and the fourth is a stud. What threads are you talking about?
Where the side adjuster screw in
[Re: justinp61]
#1620897
05/17/14 12:05 PM
05/17/14 12:05 PM
MR_P_BODY
Just out of curiosity. How much does a fully set up aluminum center section cost? Spool, gears, a good yoke and labor.
I bought mine years ago... it was much cheaper and back then I was working at Chrysler so I got a extra 25% off
[Re: Monte_Smith]
#1620903
05/17/14 03:50 PM
05/17/14 03:50 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Weight and torque is what kills an 8.75. P-body could put a big block in that thing or spray the small motor and it will snap that case like a twig.
It just doesn't matter what you do to them, you can't fix the inherit flaw in the design. The gear end of the pinion is NOT SUPPORTED. The pinion flexes, comes away from the ring gear....saws teeth off and that clogs up the works and SOMETHING has to give and that is usually the case. Housing flex is NOT what kills them, it is pinion flex. Better cases, billet caps and all that other stuff is like a bandaid on a gunshot would. Not much help
As for the OP.......the ONLY thing that is going to survive in a decent HP radial car is a Dana or a 9". RADIALS BREAK CRAP. We have a chromoly housing in our radial car and bent it several times. The new housing is also chromoly, but has .250 wall axles tubes and is braced like you would for a Pro-Mod car.......2800lbs, dead hooking tire and going 1.0 60fts STRESSES parts
Monte
I'm glad you cleared that up reg 8.75", lack of strength vs limited design, in that its the design that likely caused the failure, but I suspect there is as much ring/spool deflection as there is unsupported pinion deflection, and any combination would eventually lead to the OP's sheared tooth scenario pictured. I think the back housing brace solution is a completely separate issue. The alum factor played little part in this failure IMO that I can see.
[Re: weinerboy1]
#1620904
05/17/14 06:42 PM
05/17/14 06:42 PM
Quicktree
Years ago, my friend Dennis Maurer (Judy Lilly's crew chief) told me an 8 3/4 will never live with a tire larger than 10", carburated bbody. They're fine for light cars, low hp. Dick Gibbs.
where did you come up with weinerboy as a handle? never mind I don't want to know
[Re: Monte_Smith]
#1620907
05/17/14 10:32 PM
05/17/14 10:32 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
The nitrous was progressed at the hit so the full kit wasnt even on yet when it broke.
yeh Monte hes looking for a 9" or Dana for it now.
Car doesn't have a 727 it has a powerglide in it.
LBSR
[Re: Bill_LBSR]
#1620908
05/18/14 12:13 AM
05/18/14 12:13 AM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'll bet the track crew was PO'd. That makes a nasty mess to clean up on a starting line. Don't ask me how I know.
