727 input shaft question... #1620254
05/15/14 12:24 AM
05/15/14 12:24 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
During the Mopars at the Strip in April, I snapped the stock input shaft on the 727... I was in the burnout box, in 2nd gear and hit the go pedal.. The rear tires made 3 revolutions and stopped..
J-body, Al Aguire, Curtis and few others forced me to replace it that night with another stock piece.. so I could finish out the weekend.. Which I couldnt have done without their help..
So now its time to get a new input shaft and was trying to find a decent piece at a fair price..
The motor is 900+-ish hp and the car weighs 3100-ish with driver.. So what would you recommend and where would you get it from?
Re: 727 input shaft question... [Re: Jeepmon] #1620255
05/15/14 12:49 AM
05/15/14 12:49 AM
ky
68roadrunner Offline
ky
dont know how many people actually make these, i know a&a has them, cope probably sells them too
Re: 727 input shaft question... [Re: 68roadrunner] #1620256
05/15/14 01:11 AM
05/15/14 01:11 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
thats an item i hope i dont have to upgrade with my 572 but mine is in the 2500lb and will be foot braking, are you using a brake ? iknow the inputs are in the 6-700 price range
Re: 727 input shaft question... [Re: Jeepmon] #1620257
05/15/14 01:23 AM
05/15/14 01:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I still run with the theory that somebody attempted disassembly at some point and possibly damaged it pressing it back on. Even the "performance" hubs available are aluminum. Fluke deal for sure....
http://www.tcsproducts.com/products/product/559/
And for those following, the input shaft was fine, but the hub in which it splines to broke around the circumference of the shaft. spline area held up, but about a 1/4" in it broke all the way around.
Re: 727 input shaft question... [Re: J_BODY] #1620258
05/15/14 01:28 AM
05/15/14 01:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: 727 input shaft question... [Re: J_BODY] #1620259
05/15/14 01:30 AM
05/15/14 01:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
However.... You NEED this! ASAP
http://www.tcsproducts.com/products/product/7/
Yes he does and we were just discussing it..
Re: 727 input shaft question... [Re: Al_Alguire] #1620260
05/15/14 01:33 AM
05/15/14 01:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Added more to the list! This is fun$$$$$
Re: 727 input shaft question... [Re: J_BODY] #1620261
05/15/14 12:39 PM
05/15/14 12:39 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Its always fun when its someone else's money.. huh? lol
I thought the part I needed was this one..
http://www.coanracing.com/Catalog.asp?ProductDetail=383
Re: 727 input shaft question... [Re: Jeepmon] #1620262
05/15/14 01:05 PM
05/15/14 01:05 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The factory supplied two different input shafts, if the one you snapped was the common one you might save some money by just installing the factory HD shaft...it's identified by a groove in the splines 1/4" back from the front and (sometimes) yellow paint.
Re: 727 input shaft question... [Re: J_BODY] #1620263
05/15/14 01:07 PM
05/15/14 01:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nope you don't NEED the kickdown lever..But you do need the band strut as your was already bent then custom straightened in the trailer
Re: 727 input shaft question... [Re: Al_Alguire] #1620264
05/15/14 01:10 PM
05/15/14 01:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Actually you really need a GLIDE!!!
Re: 727 input shaft question... [Re: Al_Alguire] #1620265
05/15/14 01:27 PM
05/15/14 01:27 PM
900 HP at 3100 lbs, I would look at at a Proflyte
Re: 727 input shaft question... [Re: Al_Alguire] #1620266
05/15/14 04:34 PM
05/15/14 04:34 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Nah... nothing welding a 1/4" long carb stud to the strut can't fix... why spend $15 when you can fix it yourself for free!
Re: 727 input shaft question... [Re: dizuster] #1620267
05/15/14 05:19 PM
05/15/14 05:19 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
New drum.. input shaft and band strut has been ordered.. Thanks everyone for your help
Re: 727 input shaft question... [Re: Jeepmon] #1620268
05/15/14 05:43 PM
05/15/14 05:43 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Thats a smart move buying good parts.We broke 2 input shafts in Lisa's 904 and the second break took out the converter. I bought the 300M shaft and all has been good.Here is a pic of the second broke input, stator tube and main hub in converter. See ya at the track.
Re: 727 input shaft question... [Re: WheelsUp73] #1620269
05/15/14 06:02 PM
05/15/14 06:02 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
I have a brand new TCS billet front input shaft if anyone needs one. $500 plus shipping. Just as in the picture above. Sold racecar before installing it.
Greg
Re: 727 input shaft question... [Re: dizuster] #1620270
05/15/14 11:35 PM
05/15/14 11:35 PM
ky
ky
lol, mine has a piece of keystock welded to it, didnt know they made good ones 15 years ago
Re: 727 input shaft question... [Re: Jeepmon] #1620271
05/16/14 02:17 AM
05/16/14 02:17 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Should have bought a glide
Re: 727 input shaft question... [Re: Al_Alguire] #1620272
05/16/14 03:13 AM
05/16/14 03:13 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Like you said... "kicking and screaming"
Re: 727 input shaft question... [Re: Jeepmon] #1620273
05/16/14 05:23 AM
05/16/14 05:23 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Whats the HP level when you should upgrade? I have tcs one in garage but was told I didn't need it.
