Throttle linkage #1620078
05/14/14 02:40 PM
05/14/14 02:40 PM
Colorado Springs, Colorado
Dartthunder340 Offline OP
Can you please post some pictures of your throttle linkage or some ideas? I am using a piece or allthread and sure it works but, I would like to have a nicer, cleaner look. Should probably mention that I do have an aftermarket gas pedal and it is relocated from stock position. Thanks!
Better get inside Ma. Looks like a storm's comin'.
Re: Throttle linkage [Re: Dartthunder340] #1620079
05/14/14 03:45 PM
05/14/14 03:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would suggest a alum rod or steel with heim joints..
I've made them out of 1/4"alum rod... threaded each
end and used 1/4 X 20 female heim ends.. if its a
straight shot or use steel if you have a slight bend
