69 cuda disk brake change #1619842
05/13/14 04:52 PM
05/13/14 04:52 PM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
Yo, this is wayneo. I have a 69 cuda 383.My car came w/ manual KH disk brakes. I am changing it to manual big bolt pattern disk. I am using everything from a 73 duster. Do I have use the master cylinder & proportion valve from the duster or can I use everything that the car came with ? Mt car came w/ a small brake valve or block just past the proportion valve. Thanks for any help
Re: 69 cuda disk brake change [Re: wayne o] #1619843
05/13/14 06:39 PM
05/13/14 06:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yo wayneo, I would use the parts from the donor car if they are good .
Re: 69 cuda disk brake change [Re: JohnRR] #1619844
05/13/14 07:19 PM
05/13/14 07:19 PM
pa. usa
W
wayne o Offline OP
wayne o  Offline OP
W
pa. usa
Thanks. I am gona get a new master cylinder & ill probably have to find a proportion valve because I don't what happened to the one off the parts car. Its missing.
