Re: Brake problems
[Re: 469runner]
#1619745
05/13/14 01:55 PM
05/13/14 01:55 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Sprqay some WD40 on the brake linkage under the dash
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Brake problems
[Re: 469runner]
#1619747
05/13/14 05:15 PM
05/13/14 05:15 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The booster is probably leaking vacuum. Your complaint about the booster failing last year reinforces that.
The Imperial and D250 both made noise when I hit the pedal. Replacing the booster fixed the problem.
