Why will a bad head gasket cause a high idle? #1619689
05/13/14 02:10 AM
05/13/14 02:10 AM
Tacoma, Washington USA
Adam71Charger Offline OP
At first I thought exhaust gas, is that why? If so, will that also cause very low compression, misfire, and possibly burn up valves on the affected cylinders?
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619690
05/13/14 11:39 AM
05/13/14 11:39 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
A blown head gasket can/will cause worse things than a high idle. Usually when I think of a high idle that you can't seem to bring down, I think vacuum leak which wouldn't be a head gasket issue. A bad enough vacuum leak could cause a lean enough situation to burn a valve if left unfixed long enough.
How do you know the head gasket is bad? You are right that it will cause low compression/misfiring on the affected cylinders as the compression can 'bleed' between the cylinders and you may have anti-freeze being burned as well.
More information please!
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619691
05/13/14 11:45 AM
05/13/14 11:45 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Where did you hear/read that a blown head gasket will cause high idle ?
Re: Why will a bad head gasket cause a high idle? [Re: JohnRR] #1619692
05/13/14 07:01 PM
05/13/14 07:01 PM
My fault, I should have titled the post "will a bad head gasket.."
It was just a thought that I was checking, and a possible cause to my problem. I was never told that this was a sign of bad head gasket. Im pulling my plugs and checking compression so I can get a better idea.
As for the car and its symptoms:
Mid 70's 318, unknown mileage.
No coolant in oil, no oil in coolant, no white smoke, no black smoke. New plugs, cap, rotor, wires
new timing chain set to default position (no advance or retardation at chain)
new oil pump
carb is rebuilt within last year (by me, so not perfect but clean and set to default jetting.)
All grounds/connections have been cleaned and new wiring from the battery to the ammeter to/throughout engine and back to battery. new voltage regulator and Ballast resistor.
It is hard to start when cold, needs starting fluid, but once running for awhile, it can be turned on and off for hours and start right back up. it idles high. Given throttle with no load, it revs up fine with no problem. No clicking or rapping. But, under load, say driving 20 or 30mph, it starts to run a little less smooth, and if you gas it hard under load, it misfires and shakes but still accelerates
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619693
05/13/14 07:06 PM
05/13/14 07:06 PM
Grand Prairie,Texas
stumpy Online tonguue
stumpy  Online Tonguue
Grand Prairie,Texas
Is the choke adjusted correctly? What's the timing set at? Did you adjust the air fuel mix screws on the carb? Have you turned the idle screw down to see what it does?
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619694
05/13/14 07:10 PM
05/13/14 07:10 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Have you checked to make sure your choke is working properly?
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619695
05/13/14 07:22 PM
05/13/14 07:22 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
This sounds like a fuel-related issue. Revving the motor out-of-gear is very little load on the motor and the fuel pump. If the car can rev nice and cleanly in P or N but struggles to do the same under load (in-gear), I'd say something is starving the motor of fuel. This could be a weak fuel pump and/or gunked up carb. I have had some fuel pump issues and when the pump is partially failing, you will feel a bucking/surging while you hold the accelerator steady.
Timing could also be an issue here as well. Do you have a timing light? If so, get your initial timing (idling in-gear). Does the engine ping when you romp on it while driving?
As stated before, you might want to try and back out the idle screw a tad to see if you can bring down this high idle. A timing light would help here as well so you can get an accurate RPM reading while you do this.
This kind of discounts a blown head gasket as that would likely cause coolant in the oil and/or white smoke from burning coolant. Black smoke would indicate a super rich condition and/or weak ignition.
Keep the information coming!
Re: Why will a bad head gasket cause a high idle? [Re: Adam71Charger] #1619696
05/13/14 10:48 PM
05/13/14 10:48 PM
johnmilner Offline
johnmilner  Offline
i had a 340 blow a gasket out where the lifters are, ran perfect but sucked oil from the lifter galley smoked like crazy.
Re: Why will a bad head gasket cause a high idle? [Re: johnmilner] #1619697
05/14/14 01:58 PM
05/14/14 01:58 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
How sure are you the timing set is in right? Your symptoms are of an engine with retarded camshaft timing. Choke would either start right up and then be a pig, or be hard to start and then run well.
