BPE 4.125 Rotating Kit
#1619556
05/12/14 09:54 PM
05/12/14 09:54 PM
Posts: 9 Australia Qld
VG423
Australia Qld
A big thanks to Rod Bloomer from BPE for organizing,supplying,and shipping my 4.125 stroker kit. 13.5 dome pistons,1.5mm ring package,6.2 compstar rods,and bearings.Very happy with the service.I'm from Australia on the other side of the planet,and after reading all the positive posts on moparts,i am now another satisfied customer of BPE. Thanks to Rod for the great options for us mopar guys. Cheers Peter. ![](/ubbthreads/images/graemlins/beer.gif)
Re: BPE 4.125 Rotating Kit
[Re: VG423]
#1619557
05/12/14 09:59 PM
05/12/14 09:59 PM
VG423
Australia Qld
Photo1. 13.5 comp 4.040 pistons 4.125 360 mains crank 423 inches .
[Re: VG423]
#1619559
05/13/14 12:20 AM
05/13/14 12:20 AM
Posts: 3,425 Toronto
mshred
Toronto
Rod is a good dude! Takes care of the customer and makes sure EVERYTHING is right! The business needs more guys as dedicated as him ![](/ubbthreads/images/graemlins/thumbs.gif) Good to hear you are satisfied and your stuff arrived where your at safely
[Re: mopar dave]
#1619564
05/13/14 10:36 PM
05/13/14 10:36 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
https://board.moparts.org/ubbthreads/show...rue#Post8027266Dave, you can check out my pump gas build, complete with invoices... The pistons are Race-Tec. I've always been a big block guy, and when I started to do the small block, my thought was "I wish 440 source did small block kits!" After my experience with Rod at BPE, my feeling is more like, "I wish he did big block kits!!"
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: mopar dave]
#1619566
05/14/14 02:06 AM
05/14/14 02:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
ok, I will when I get ready for next rebuild. do you think those pop ups cost any power compared to a flat top? what brand piston?
Dave... on the pistons thats sorta hard to say...to run them on the dyno then change over to a flat top and cut that much off the chamber most guys would never try... I myself try to run the flattest possible but I also have a .100 raised section to give me 14.1:1 on my W-9 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: DblOJoe]
#1619573
05/14/14 06:00 PM
05/14/14 06:00 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Boy, you guys with stock blocks who have intentions of making serious steam have way more kahunas than I would have using huge stroke cranks. Of course having already broken a stock block motor and haveing had to build another motor, my concerns are probably more dollars and cents based. Tossing 4.125/4.25 strokes around in stock blocks with serious power thoughts in mind wouldn't make me sleep well ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: B3422W5]
#1619575
05/15/14 12:42 PM
05/15/14 12:42 PM
kielbasa
i couldn't agree more - if i had to do it over again, i should have went aftermarket block...
