440 Main Bearing Question #1619551
05/12/14 09:48 PM
05/12/14 09:48 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
I'm rebuilding a 69 440 for a friend.This is a stock rebuild.Nothing fancy,just a nice rebuild.Ordered main bearings from Summit,Clevite MS1277P-10.These are suppose to be tri-metal 1/2 groove.Recieved them today and they are full groove.Should I be concerned,any difference full to 1/2 groove.Any input would be great. Thanks,John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 440 Main Bearing Question [Re: charge70] #1619552
05/12/14 09:54 PM
05/12/14 09:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
no problems.. use them.
I am truckless..
Re: 440 Main Bearing Question [Re: 340SHORTY] #1619553
05/12/14 10:12 PM
05/12/14 10:12 PM
IN
ahy Offline
ahy  Offline
IN
Full groove provide continuous oiling to the rods... which many builders think is a good thing. I run them in my wedge for that reason. They do use more oil and will probably reduce oil pressure at hot idle somewhat. With a high volume oil pump no problem with standard or typical high po main/rod clearances up to .0024" or so.
The standard OP may be OK but if it were mine I'd go ahead and put the high volume version in with full groove bearings.
Re: 440 Main Bearing Question [Re: ahy] #1619554
05/12/14 10:56 PM
05/12/14 10:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the full grooves will have more oil clearance. probably ought to mock up the main bores/crank and check the clearances or use the 4924 bearing set. i'm going thru some bearing issues now and all I can say is stuff ain't what it used to be.
Re: 440 Main Bearing Question [Re: lewtot184] #1619555
05/12/14 11:45 PM
05/12/14 11:45 PM
KING Race bearings are the best stuff out there
1277's ? Use them in a heartbeat , never look back, will be fine--that is a very narrow groove compared to the old Mopar/Clevites we used to run in everything.
No worry, slap them in and go! Use whatever oil pump you have and forget it.
