Thanks for helping
The thermoquad carb on my car was dripping gas around the bowl vent, plus i know the top gasket was weak from taking it apart a few times, so i took it off for a rebuild
i'm also replacing the performer 440 manifold with an indy 2d. car has rpm heads, 231/237 @0.050, ~0.560 lift, tti headers, 2.5" exh, 2.76 rear and a 727 automatic
so my question is about the fuel pump. the car would i think starve for fuel in long 1st or 2nd gear pulls, around 4000rpm. it has 276's so it takes a while... i have a wideband and the tq is pretty spot on till it starts missing and goes lean, so i figure it is emptying the bowls??
i put a new stock fuel pump on for $40 and not much difference
I was thinking a carter M4862
http://www.summitracing.com/parts/crt-m4862/overview/make/chrysleror something like that. i'd like to run a -6 AN line to the carb, i have a fitting on it, and i dunno if i need a regulator for a pump like that? i surely want a mechanical pump
also should i think about up-sizing the line to the tank. it's probably 5/16"
cheers and thanks Moparts
