Page 3 of 4 1 2 3 4
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618478
05/14/14 02:32 PM
05/14/14 02:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Assuming we don't have the option to change crossmembers, ride heights, or anything else...
So if you have a trans that has 2 degree's to the driveshaft.
Options/opinions are:
1) Give the pinion 2 degree's (under load) to be equal and opposite of the trans.
or
2) Give the pinion 0 degree's under load so at least 1 of the joints is optimized.
That's basically the two opinions we're talking about here right?
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dizuster] #1618479
05/14/14 02:44 PM
05/14/14 02:44 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Here is an interesting excerpt from circle track magazine. They actually found that having the angles EQUAL AND OPPOSITE made more HP at the tire then getting the driveshaft as straight as possible...
VERY interesting...
"At the end of the last set of runs, we experimented with pinion angles and actually learned some interesting facts. Our Winston Cup consulting engineer, Terry Satchell, told us the most important factor in pinion/driveshaft/transmission angles was to have equal angles at each end of the driveshaft. This would be the most efficient design, yielding less loss of horsepower from bearing bind at the chassis attitude that is the result of the car accelerating. What we discovered was not what we had expected.
We did experience a slight gain in horsepower due to changes in the pinion angle. We could not change the transmission angle, so all of the changes were to the pinion. We recorded a run at zero pinion angle and then at 10 degrees of pinion angle. We expected a loss in horsepower at the greater pinion angle, but actually experienced a net gain in horsepower. This was very confusing until we thought about what Terry had said. When the pinion was at 10 degrees, the angles at the ends of the driveshaft were opposite and closer to equal. This was a better situation providing less resistance than when the pinion was at zero degrees with the transmission angle at a much different angle.
Most racers only measure the pinion angle relative to the ground when they should measure both the pinion and transmission angles relative to the driveshaft. The angles should be equal and either opposite or in the same direction to help eliminate vibration and drag through the U-joints.
This yields more rear wheel horsepower as well as longer component life due to vibration-free movement as the bearings rotate.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dizuster] #1618480
05/14/14 03:29 PM
05/14/14 03:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Equal angle or angles that parallel each other is the same interpetation.This is the best situation when when the trans is higher or lower than the rearend.If your building a chassis then it is best to locate both componants as near as straight as possible and set for the torqued or loaded change.As far as circle track cars are concerned,they shouldn't be compared to a drag car.A drag car should be built as stiff as possible and travels in a staight line under constant load,a circle track car chassis has a flex factor to contend with as well as loading and unloading of both the chassis and drivetrain.To apply circle track tech to a drag car would like to try and breed a poodle and a tiger,some thing bad is going to happen.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: B G Racing] #1618481
05/14/14 03:45 PM
05/14/14 03:45 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I wasn't making the point that this was a circle track car.
My point was that they dyno'd a car (any car), and on the chassis dyno the equal and opposite angles made more horsepower to the tire then when they had the pinion set to 0 degree's.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dizuster] #1618482
05/14/14 03:51 PM
05/14/14 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know how that can be... if you have a engine/trans
in line with a solid shaft(no U-joints) to the diff
how can that eat power... basically we are trying
to eliminate the U-joints from the picture
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: MR_P_BODY] #1618483
05/14/14 04:00 PM
05/14/14 04:00 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I think their point was that having the trans at 10 degree's and the pinion at zero, actually made less power then having them at 10 and 10.
Clearly having both at zero would make max power. But as many have pointed out, sometimes it hard to change the trans angle. Looks like this is at least one example where equal and opposite angles made more power then just focusing on getting the pinion to zero.
My guess is the harmonics rob more power then the equal/opposite angles.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dizuster] #1618484
05/14/14 04:42 PM
05/14/14 04:42 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
The method of not accounting for the angle of the transmission is described in the Direct Connection chassis manual and they call it "driveshaft angle" and "rear u-joint angle"...must be something different than pinion angle?
When I called Calvert Racing to find out where to set my "pinion angle" when installing Caltracs Travis replied "3° nose down to transmission, not driveshaft" I just chuckled and said yup.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Quicktree] #1618485
05/14/14 06:04 PM
05/14/14 06:04 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
You're kind of stuck with the vertical rear u-joint location where it is. That's determined by the type of rear and tire size. A 9" with a 32" tire is around 13 3/4" off the ground. If you are able to install the engine/trans assembly in a location that allows the operating angles to be correct, while having the trans centerline parallel with the pinion centerline, that's great.
The "chart" is great except that it doesn't consider that the pinion centerline could be higher than the trans centerline with the front of the engine higher than the front u-joint. I've worked on plenty of lowered and backhalved cars with the engine/trans on stock mounts and angled down a couple of degrees or more front to rear. In order to get the pinion parallel with the trans, the pinion angle would have to go positive (definitely not acceptable). A lot of these cars end up with a "broken back" configuration to keep the pinon angle negative.
If the car was built with the driveline stringlined from the front of the crank, through the center of the trans, to the center of the pinion, it makes it easy. Most cars weren't and you have to work with what you have to maintain the pinion angle where it needs to be. Not a lot of wiggle room with the pinion angle. At some point, you have to live with it or move the engine/trans mounts. Stock front clip and/or stock floors? That makes it even tougher.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: 496 A-body] #1618486
05/14/14 06:04 PM
05/14/14 06:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Let's define pinion angle in it's simplest form that most incounter on their cars.The engine and trans are located by the mounts,the rearend is located by it's mounting points.Depending on your type of suspension you can calculate how much pitch or upward rotation you need to best align the ujoint under load.The trans position is fix,so the rear u-joint is where the binding may occur and that is what needs the attention.As has been repeated many times,springs need 4 to 6 degrees negative of the driveshaft angle,ladder bars 2 degrees negative of the driveshaft angle and 4 links need only 1 degree negative of the driveshaft angle.We did a lot of testing and have videos of the the rear end pitch and upward rotation as the car was launched under load on the strip.You can view some of these videos on Bob George Racing on U-Tube.Most all racers,chassis shops and builders use the method we have describing to set pinion angle.We like many others understand there are other methods but we tend to stick with what has worked for us for over 50 years.To give an example our 65 Hemi has had the same driveshaft and u-joints for almost 20 years and thousands of passes.The KISS method of setting pinion angle is the lest complicated and works.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: CMcAllister] #1618487
05/14/14 06:17 PM
05/14/14 06:17 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Why is it definitely not acceptable? I don't understand exactly why the car would care...
If the pinion and output shaft are parallel... the angles HAVE to be the same. They could both be 2 degree's... or they might both be 10 degree's. But they are equal.
What the circle track article referenced above showed on the dyno that having both of them at 10 degree's to the driveshaft, is better then having the front at 10 degree's and the rear at 0.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: CMcAllister] #1618488
05/14/14 07:27 PM
05/14/14 07:27 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
As long as the trans and pinion centerline angles are equal and opposite what does it matter if the pinion centerline is above or below the trans centerline?
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: dizuster] #1618489
05/14/14 08:17 PM
05/14/14 08:17 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
or
2) Give the pinion 0 degree's under load "to the driveshaft so at least 1 of the joints is optimized.
Number 1 is the correct method. Number 2 is the Incorrect method.
You Cant optimize 1 ujount angle. They Work in sink with one another.
Sure you have one Less angle, But thats a Bad thing. Yes it will work. But its working in a bind eating HP.
The Type of Vids I referred to earlier can and will Clearly show this. Wish I could Link them.
#1 The Best Angle is No angle. #1
#2 Next would be Parallel angles on seperate planes #2 "80% of us'
"3 There isnt a #3 IMO But if there must be, Measure off the shaft, its workable, but a guess.
No flared temper here either
Just the Tech Facts.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Sport440] #1618490
05/14/14 08:28 PM
05/14/14 08:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
or
I'll stick with the way I do it... thats the best
way... so everything is in line and zero hp taken..
so this is the last post for me on this crap
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: MR_P_BODY] #1618491
05/14/14 08:50 PM
05/14/14 08:50 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mike, Yep that is the Best way as per my post #1
Also, I think you interpreted that circle track dyno test wrong.
When they used 0 degrees pinion that was with the shaft.
Not the tranny/shaft/pinion like you thought, That would be best.
Its when they "added angle" to make the joints more parallel to the two seperate planes that they got more HP. Understandable IMO.
That was my interpretation.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Sport440] #1618492
05/15/14 12:51 AM
05/15/14 12:51 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Yep......I am out as well. This has wasted enough of my time. I know what works for me and I will continue to do so.
As far as the statement above about the trans being 2* down, meaning the rear would have to be 2* up and somebody thinking that was CORRECT just because angles were equal on both ends. Try that in a high HP hard leaving car and let me know how it goes. Just make sure you have good loops and some extra parts.......LOL!!!
Monte
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Monte_Smith] #1618493
05/15/14 02:16 AM
05/15/14 02:16 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Monte
The Term used was "Under load", so your numbers would be correct Plus "Equal and Opposite" angles. Witch would make them Ideal and parallel under load.
It was just a example of a perfect scenario of two different planes of the two centerlines that we stock bodied cars see.
A perfect scenario of a Wrong example was #2 where the angle of the pinion was 0 with the shaft, but not with the tranny.
U joints dont work that way, they will be in a bind and eat HP.
Those are the Facts Mam
or maybe just my opinion of the facts.
Everthing is fine though 10 years + going on, the two pinion angle camps have never seen eye to eye. But we still get along.
In reality, our street/race car pinion angles will be so dynamic in pinion movement, that your two methods of choice wont make a whole lot of difference.
But technically/factually U joints work together and they want to be in sync., working in Parallel angles. Whether it be straight or on different planes. If there not, they are binding. We set Pinion angle to Best get them there under load.
This is a Fact, not a Opinion.
IMO, This part of it, should never ever be the Debate part of it.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Sport440] #1618494
05/15/14 02:47 AM
05/15/14 02:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Nope........if it was FACT as you say, there would not be two obviously opposing sides. As with most everything, it is strictly opinion as to what guys thinks works the best.
You can show me all the charts, graphs, diagrams and anything else you want, but that doesn't make it fact. It makes it the opinion of the guy that drew them.
And facts or not, try the trans down, pinion up scenario that was mentioned above with any significant offset and a high hp car will spit out driveline parts faster than you can fix them. And while this result may not be a fact, it is something I KNOW will happen.
Monte
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Monte_Smith] #1618495
05/15/14 09:33 AM
05/15/14 09:33 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Monte
http://www.rosslertrans.com/Pinion%20angle.htm
I guess somebody better contact these guys and let them know that they need to get their act together and correct the misleading information they have provided to guys running their transmissions in very high horsepower applications before they get swarmed with lawsuits from guys who have spit driveline components.
I've also been told by a DC bible thumper that I shouldn't use this method because Rossler is a GM guy, anyone who would make such a statement just reinforces the fact that they are an IDIOT!
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: Sport440] #1618496
05/15/14 09:41 AM
05/15/14 09:41 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Monte
2° trans down and 2° pinion up is parallel and the relative pinion angle would be 0° under load...Not 2° nose up which is what I think some of these guys are interpreting it as...drive shaft angle is irrelevant as u-joint angle will be equal and opposite at both joints.
Re: WHAT IS THE TOOL TO SET PINION ANGLES [Re: 496 A-body] #1618497
05/15/14 12:23 PM
05/15/14 12:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Been reading all this and thought i would add one thing. When a u-joint is angled one side speeds up and the other side slows down hence loss of hp. So the idea of both joints being opposite but same angle would cancel out the speeding up and slowing down. I would still like to have them straight as possible but very hard to get in a regular chassis. The best joint would be a CV(constant velocity) type, no speeding up or slowing down.
Page 3 of 4 1 2 3 4
