suregrip diff
#1617985
05/09/14 01:21 AM
05/09/14 01:21 AM
Posts: 21 Toronto, Ontario
mjharman
Toronto, Ontario
I was wondering (1) is the 742 rearend better/stonger than the 489 rear diff (2) would the 69 roadrunner have one vs the other specific rear end saying that do all roadrunners have the same rear end other than a dana ??? Thanx ....Mike
69 Roadrunner 440 4speed
Re: suregrip diff
[Re: mjharman]
#1617986
05/09/14 01:31 AM
05/09/14 01:31 AM
RapidRobert
the power lock sure grip type in the 742 case is far stronger than the cone type sure grip in the 489 case sure grip. There was a recent post on when the changeover was & iirc it was mid 68 model year but you know how Ma was with carryovers/poor record keeping & yours could have swapped out. Cant miss the big cast numbers on the side
Re: suregrip diff
[Re: 1965_PLYMOUTH]
#1617988
05/09/14 01:52 AM
05/09/14 01:52 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IMO the weak point in all of them is the threaded end of the pinon shaft.
I am truckless..
Re: suregrip diff
[Re: 340SHORTY]
#1617989
05/09/14 02:22 AM
05/09/14 02:22 AM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Huh?
IMO, the weak point of the different diff units themselves is whether it's a cone or clutch, now besides that pay CLOSE attention to the condition of the splines on the side gears.
If you don't know what I am talking about then you don't know.
Re: suregrip diff
[Re: mjharman]
#1617991
05/09/14 11:27 AM
05/09/14 11:27 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
742 is the better/stronger rear , 69 road runner would have a 489 case with a cone type puke: sure grip
Re: suregrip diff
[Re: JohnRR]
#1617992
05/09/14 01:39 PM
05/09/14 01:39 PM
dogdays
A different take on the issue:
1. When the aftermarket decided to make an aluminum center section they picked the 742. I bet at least some of that reason was because they thought it was stronger. And I'm assuming that the aftermarket designers knew the crush sleeve of the 489 case could be replaced with a spacer to take out that weak link.
2. For every story about twisting off a pinion shaft, there are 10 or more stories about breaking gears. What happens to break a differential is that the two gears are trying to push away from each other, and the farther they push apart, the more leverage the tooth has on the root. In other words, when the gears push apart the gear teeth are apt to break off. Now as each of the three types has the same diameter ring gear and pinion gear, the only difference is the stiffness in bending of the pinion itself. Again, the 489 case in this example has a spacer, not a crush sleeve.
So IMHO there is not a lot of difference between the two, and I'll also say if you are worrying about breaking one when the "stronger" one may not break, you are wasting your time. Get a Dana 60 and be done with worrying.
R.
Re: suregrip diff
[Re: Rustydog]
#1617994
05/09/14 02:36 PM
05/09/14 02:36 PM
Pacnorthcuda
Yep, a whole lotta splitting of the hairs tween 741, 742, and 489s.
As long as the diff is not a cone, and if it's a 489 it's got a solid spacer, I'm good with any of them for a street car, street tires.
Re: suregrip diff
[Re: OhioMopar]
#1617999
05/10/14 02:44 PM
05/10/14 02:44 PM
JohnRR
This debate is very interesting to me and I like reading it every time it comes up. Each time, the end result is maybe I need to forget about getting another center for my 4-speed Bee and go straight to the Dana. It will see more street use, but it will get regular track flogging as well.
Buy once or buy twice ...
