Re: 727 pan gasket
[Re: RO23dave]
#1617934
05/09/14 05:37 AM
05/09/14 05:37 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
The late model factory gasket is one of the best there is, and is reusable.
It looks to me like you got a similar answer in your previous post.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
Re: 727 pan gasket
[Re: justinp61]
#1617936
05/09/14 11:54 AM
05/09/14 11:54 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
I had trouble with the late gasket leaking with my stamped deep pan. The embossed o ring hit in the recesses in a couple places. It would work great with an aluminum pan with a machined surface.
factory pans, on which the gaskets are used, are stamped steel. Works great What you may want to do is get a pan from a 46RE/47RE trans (pickup trans). They actually have pretty decent depth.
