Ballast Resistor? #1617854
05/08/14 07:42 PM
05/08/14 07:42 PM
Colorado
Hem1orange Offline OP
Colorado
I'm installing a complete MSD Atomic fuel injection system with MSD distributor and coil. Will I need a Ballast resistor with the coil? or should I run straight 12 volt source?
Thanks in advance
Ron
Re: Ballast Resistor? [Re: Hem1orange] #1617855
05/08/14 07:50 PM
05/08/14 07:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The instructions should have come with the parts and that will give you the correct voltage requirements of the coil.
Re: Ballast Resistor? [Re: Hem1orange] #1617856
05/08/14 07:55 PM
05/08/14 07:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks in advance
Ron
i'm gonna say no as it comes with it's own ECU. which coil? i would suggest their 'vibration proof' epoxy coil but you don't need a ballast with the blaster.
Re: Ballast Resistor? [Re: stumpy] #1617857
05/08/14 07:57 PM
05/08/14 07:57 PM
Colorado
Colorado
Thanks stumpy.
I will dig through what I have.
Ron
