Re: Are marine engines REALLY that bad?
[Re: Greg55_99]
#1617707
11/14/14 06:04 PM
11/14/14 06:04 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
I believe it's fresh water cooled. It's on a pallet and has supposedly been rebult along with the boat transmission. I don't need the transmission and he'll let the motor go for $500. Of course that could be false economy. I have a set of 69 440 heads and other parts from a car so I'm mainly interested in getting a good short block. Reverse rotation is no good to me.
Greg
Rebuilt for $500 ??? Treat that as a CORE, do NOT assume just because it's got a shiny paint job that it has been REBUILT ?? Also what pistons are in it ? It could be low compression ???
[Re: JohnRR]
#1617708
11/14/14 06:29 PM
11/14/14 06:29 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Greg
About 30 years ago I bought a beat up old flatbottom/v-drive that I got just for all the parts I needed for a boat I was building - exhaust manifolds, steering gear, v-drive unit, etc..it also had the "rebuilt" 413 referenced in my reply above. I never trust anybody's "rebuild" anyways, so I tore it down for a look-see. I found 2 finger-tight headbolts, and the 8-bolt flywheel was held on with 5 bolts and nuts, one of which was one size smaller then the rest and flopping around in it's hole. It was at .030" over, so I had it punched to .060", and it cracked a wall within a month.
No more backyard rebuilds or saltwater blocks for me.
[Re: vdriver]
#1617709
11/14/14 09:08 PM
11/14/14 09:08 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
How to spot right hand, or reverse, rotation.
Pull dist, look at the dist drive and cam gears, they will be cut backward compared to a left hand, or standard/automotive, rotation. This is so with the backwards spinning cam, the oil pump will turn in the proper direction. There may also be a thrust "spacer" to keep the dist drive gear from walking away from the oil pump, LH rotation pushes the drive gear down, RH pushes the gear up.
