Spark Plug Wires - need longer set for Max Wedge #1617395
05/07/14 11:55 AM
05/07/14 11:55 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Does anyone have a contact for longer spark plug wires? I have a Max Wedge and the stock brown wires appear to be a little short to reach the rear on the driver's side. I would like to match up the new wires with the stock appearing (dark brown) wires. I was not sure if there were companies out there making longer wires.
Re: Spark Plug Wires - need longer set for Max Wedge [Re: vinnyd76] #1617396
05/07/14 02:43 PM
05/07/14 02:43 PM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
Are you looking for individual wires or a full set? Have you checked FireCore? https://www.customwiresets.com/product.php?productid=16237&cat=305&page=1
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Spark Plug Wires - need longer set for Max Wedge [Re: vinnyd76] #1617397
05/07/14 06:17 PM
05/07/14 06:17 PM
If another set of the same ones you have is cheap enough you could just buy another set & use what you need from it. I'm assuming you have switched the wires around & no go. would going underneath be a way out?
