Re: Help with gear selection
[Re: Beep Beep]
#1617347
05/07/14 01:06 PM
05/07/14 01:06 PM
RapidRobert
3:91 sure grips are desireable & I'd pull the pig & sell it then buy a 3.23 or 3.55 clutch type sure grip then install the 1350 yoke if desired. if it's a 742 case (my recommendation) no need to mess with the innards when changing the yoke to the 1350. I think you'd be time & money ahead to do it that way
[Re: Beep Beep]
#1617349
05/07/14 02:46 PM
05/07/14 02:46 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
I forget to mention that it is an 8 3/4 489 case with a new auburn posi and I have a lot of money in this pumpkin, just like everything else on this car. Lol
Auburn unit. Sell it as is,even at a loss, and start over with a power lock diff loaded with 3.55s
[Re: Pacnorthcuda]
#1617350
05/07/14 02:55 PM
05/07/14 02:55 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
I'd say put a gear vendors on the ride but it might be cheaper to go another route....Still....drivablity with the GVO off, and the better MPG with it engaged...you get two rear ends for the price of one...I have a 440 spinning 2200 rpm @60mph with 3.55 and 28" tires (final drive is like a 2.76)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: dogdays]
#1617354
05/07/14 11:16 PM
05/07/14 11:16 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Perhaps a Passon overdrive 4 speed. I am running 4:10 with passon and 275:60:15's (28 inch)at 75 mph mph doing 3k rpm,,,if tach and speedo to be believed. Running 512 stroker 6 PAC. Performance is excellent. Now wish I had a 390 or better yet a 370 gear for a bit better highway fuel mileage. Car has so much low rpm grunt, could likely even run a 355 gear, but probably would not.
A bit more expensive buying a gear set from Passon, but likely a lot more flexibility and joy. 5 speed even better, but now talking real big bucks,,,not convinced worth it
