Splash-zone epoxy test. coated and un-coated RESULTS #1617166
05/06/14 05:28 PM
05/06/14 05:28 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Doing a little test and will post results if anyone is interested. I took 3 globs of Splash-zone epoxy (A-788) and weighed each one after drilling them and placing a piece of tig wire thru them so I could submerse them in alcohol and BP93 to see how they held up. I have them numbered as such.
#1. Alcohol, un-coated, weights 55 grams
#2. Alcohol, brushed on one coat of MinWax polyurethane, 55 grams
#3. BP93 pump gas, one coat MinWax, 45 grams
These where placed in glass olive jars on 5-6-14 at app. 2:30pm and after a few days I will remove and weigh each sample again and inspect to see how they are holding up. Here are a few pictures.
Lets see what happen as alcohol is in lots of gas we now buy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617167
05/06/14 05:37 PM
05/06/14 05:37 PM
ohio
all spooled up Offline
ohio
thanks let us know
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617168
05/06/14 05:38 PM
05/06/14 05:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is BP93 an E10 blend? That's all it took (10% ethanol) for Moroso A/B epoxy to soften up in my intake manifold.
It may not be a weight difference you see as much as a consistency change. The patches I put in my intake that hadn't been "ingested" by the engine had softened up due to exposure to ethanol and were able to be peeled back something like putty, despite all the footholds I'd created on the surface for the epoxy to bond to.
Definitely interested in hearing about your results w/ the coating.
Re: Splash-zone epoxy test. coated and un-coated [Re: BradH] #1617169
05/06/14 05:43 PM
05/06/14 05:43 PM
PA.
"Little"John
"Little"John
PA.
Its being tested in real life on my sons 360 Duster in the near future. I tube all the Edelbrock heads I port but I also smear a light coat of splash-zone over the tubing. He runs alcohol so this will be a good track tested test. I coated his heads.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617170
05/06/14 05:47 PM
05/06/14 05:47 PM
PA.
"Little"John
"Little"John
PA.
Brad I'm not sure about BP93 and the 10% alcohol but on the pump for all 3 grades it states "gas may have up to 10% alcohol content". I've been told that the 93 grade doesn't but you know how that goes. I got away from using Moroso AB epoxy when it started flaking off on to many projects.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617171
05/06/14 05:55 PM
05/06/14 05:55 PM
BradH Offline
BradH  Offline
I was going to try Splash-Zone after the Moroso AB didn't work out, but heard it's not alcohol-proof either.
The only product I've found that seems to hold up to alcohol is Belzona (#111?), but that sh!t's priced like gold and I don't need nearly as much as the minimum purchase amount requires.
That's why I'm interested in seeing how your top-coat on Splash-Zone holds up.
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617172
05/06/14 06:12 PM
05/06/14 06:12 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
John, how long did these test samples cure before you submersed them in the fuels?
Re: Splash-zone epoxy test. coated and un-coated [Re: roadhazard] #1617173
05/06/14 06:14 PM
05/06/14 06:14 PM
PA.
"Little"John
"Little"John
PA.
over 3 days and I set them outside in the sun all day on Sunday.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617174
05/06/14 07:09 PM
05/06/14 07:09 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
It is easy to check the jokenol content of gas. Get a container, the one I use is a 100ml graduated cylinder but I think any will do. I put 20ml of water and then fill to 100ml by adding 80ml of gas. Shake it up and let it settle. if there is jokenol in the gas it will separate creating very corrosive jokenol-water. If there is 10% jokenol you will now have 28ml j-w and 72ml gas.
Re: Splash-zone epoxy test. coated and un-coated [Re: Airwoofer] #1617175
05/15/14 06:42 PM
05/15/14 06:42 PM
PA.
"Little"John
"Little"John
PA.
Time for some strange results.
I removed the 3 samples last night at 10pm (5-14-14) so they have been left soaking for slightly over 8 days. When I removed then I placed them out to dry till 4pm (5-15-14)
#1 started out at 50 grams, uncoated, and placed in alcohol. today's weight was 50 grams, very good physical appearance, and held up very good when I tried scratching it with a scribe. Alcohol when removed was still purple.
Now the strange results.
#2 started out at 55 grams, coated, and weighed 55 grams
when removed last night coating was somewhat wrinkly in appearance.
sample now weights 60 grams (5 grams more) looks good but is off color, tested great when scratched with a scribe, BUT the alcohol is now CLEAR instead of purple.
#3. Pump gas (bp93) coated, 45 grams entering test
when pulled last night coating was again wrinkly.
weighted 50 grams in today's weigh-in (5 grams more), looked good but off color. both coated samples lost the nice shine from the coating before the test started, responded nicely to the scratch test and probing with the scribe. Pictures are from today.
Really happy with the Splash-zone after being soaked constantly for that long but I may try some ppg clear coat with hardner for the next test.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617176
05/15/14 08:56 PM
05/15/14 08:56 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I did this test years ago and what was strange is all the epoxys I let soak in Alcohol stayed good but JB weld in running engine or AB epoxy would not make 4 passes in w2 pushrod Area on alky and heads had JB weld in the for 100 plus passes on race gas.
Somthing with heat and evaporation in running engine is hard on epoxy.
Try air plane "dope" for wing covering alky nitro Resistant helps buy some time.
Re: Splash-zone epoxy test. coated and un-coated RESULTS [Re: pittsburghracer] #1617177
05/15/14 09:07 PM
05/15/14 09:07 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Nice test and reporting BTW. I have no dog in this fight. But if someone was to repeat with a variation, based on others comments, I might suggest a non immersion test, with sample in a sealed container, suspended just over the liquid fuel. You might be gaining some protection with the liquids that if vaporized will not provide. Just a thought. I would also attach blob to a typical metal and perform a peel test at end, compared to non fueled blob
Re: Splash-zone epoxy test. coated and un-coated RESULTS [Re: jcc] #1617178
05/15/14 09:17 PM
05/15/14 09:17 PM
PA.
"Little"John
"Little"John
PA.
I should add to this that track tested results will be available next Winter as I used splash-zone and coating on Matts 10.50 small block edelbrock heads and he runs alcohol.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated RESULTS [Re: pittsburghracer] #1617179
08/06/14 09:25 PM
08/06/14 09:25 PM
PA.
"Little"John
"Little"John
PA.
UPDATE 8-6-14
I just happened to take a look at my epoxy samples today that have been sitting on my work bench in my shop. Number 1 and 2 both look great but #3 the pump gas sample had about a 1/2 inch crack across it. It was the one that weighted more when I removed it from the jar. I honestly expected to see the alcohol ones suffer the most.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated RESULTS [Re: pittsburghracer] #1617180
08/08/14 01:05 PM
08/08/14 01:05 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
BP 93 pump gas here in IL. last I checked had 12% ethanol in it. Mid June when I tested it.
Could be a variable causing diff. results?
Don
Re: Splash-zone epoxy test. coated and un-coated RESULTS [Re: cudadon] #1617181
08/08/14 01:16 PM
08/08/14 01:16 PM
PA.
"Little"John
"Little"John
PA.
Don
Something seems to have changed with BP93. My Duster used to print time-slips until this year and that is why I made the switch to alcohol last weekend. I only had 2 time trials before the rain moved in but I am heading to the track this weekend to try my luck.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: W5DART66] #1617182
08/08/14 01:29 PM
08/08/14 01:29 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
So does the Moroso AB hold up to race gas OK ?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Splash-zone epoxy test. coated and un-coated [Re: Hemi Allstate] #1617183
08/08/14 02:56 PM
08/08/14 02:56 PM
PA.
"Little"John
"Little"John
PA.
Thanks,
Mark
Mark I've used Moroso epoxy but I made the switch to Splash-zone. I still have a pac laying around unused. I sealed the tubing on my Sons Edelbrock head and after short use it was peeling away. With Splash-zone you can mix it and apply it (I use Doctor gloves, the thin type you get at Harbor Freight) then you can wet it and really form it to the needed shapes. Goodson sells it in small containers under their brand name and is a really good company to deal with.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Splash-zone epoxy test. coated and un-coated [Re: pittsburghracer] #1617184
08/08/14 03:18 PM
08/08/14 03:18 PM
Mt. Eden Ky.
Mt. Eden Ky.
Hmmm.......
Well my problem is I have done a lot of epoxy filling inside my old Rat Roaster intake, and I used the Moroso Epoxy.
My engine is a pump gas build, but if it would save the epoxy work, I would use race fuel when I switch to the RR.
Perhaps a coating as mentioned above would help protect the work I have already done!?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Splash-zone epoxy test. coated and un-coated [Re: Hemi Allstate] #1617185
08/08/14 05:00 PM
08/08/14 05:00 PM
PA.
"Little"John
"Little"John
PA.
Hmmm.......
Thanks,
Mark
Mark DON'T use the coating that I used. It didn't work at all. Let me see if I can find a link from Darren Morgan as he has done more of this than I ever will. I used to have a clear coat spray can that I used but the top broke when it fell from my workbench.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
