Re: 73 Duster disk brake proportioning assembly
[Re: babarracuda]
#1616896
05/06/14 07:45 PM
05/06/14 07:45 PM
RapidRobert
what system (73 duster I'm assuming) are you working with now & what part or parts are you considering adding/changing? More info please
[Re: babarracuda]
#1616898
05/07/14 02:07 PM
05/07/14 02:07 PM
RapidRobert
disc/drums I'm assuming. Not enough braking is the complaint? what bore MC/what calipers. I'm assuming the rear drums are spooned up & there ain't no air in the system (they dont pump up)
[Re: RapidRobert]
#1616899
05/08/14 12:29 AM
05/08/14 12:29 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ted...My 73 Duster has a 1 1/32 inch piston bore...with the stock proportioning valve...
I removed the power brake booster and the brakes are manual with the newer 2 bolt master cylinder.
This is the car he is referring to.
