What fuel for 408 #1616673
05/05/14 07:57 PM
05/05/14 07:57 PM
Indy
moparman89 Offline OP
Indy
I'd just like to get some thoughts on what fuel you would run for this combination.
408"
10.7-1 comp
RHS iron head
236/242 .600/.600 110
Holley 830
Spins 6500ish
Street/strip
School of Automotive Machinists Racing
Re: What fuel for 408 [Re: moparman89] #1616674
05/05/14 08:46 PM
05/05/14 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your cranking pressure
Re: What fuel for 408 [Re: MR_P_BODY] #1616675
05/06/14 10:33 AM
05/06/14 10:33 AM
Indy
Indy
Havent tested cranking pressure yet
Re: What fuel for 408 [Re: moparman89] #1616676
05/06/14 10:47 PM
05/06/14 10:47 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have a 394 and it has 191-200 cranking comp. and aluminum heads and I run nothing but 93 octane.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What fuel for 408 [Re: D-50] #1616677
05/07/14 02:48 AM
05/07/14 02:48 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think you will ping at that ratio with iron heads and that small of a camshaft.
I think you can run pump premium and throw in a gallon or 2 of 110 with each tank.
Re: What fuel for 408 [Re: viperblue72] #1616678
05/07/14 01:55 PM
05/07/14 01:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont know if your eng has quench as that would help. I have quench and aluminum heads and at 10.6 comp I run fine on 92 pump. Ron
