Assembling the front suspension today. An update!
#1616423
05/05/14 11:58 AM
05/05/14 11:58 AM
Posts: 5,910 Athens, Greece
Pyper70
Athens, Greece
Aside from the obvious grease fittings...Where else is advised to grease up or lube? Everything is rubber on the suspension except for the UCA bump stops and the Swaybar bushings, those are both Poly's
~Should I lube the eccentric bolts for the UCA's to make wheel alignment a little easier (at least the first time setup)?
~How about the pivot shafts for the LCA's into the K-Member?
~Should I apply Anti-seize compound on the Torsion bar bolts
Everything else is pretty much gonna cranked down with a torque wrench, with cotter pins.
One thing to note, We bought the Strut Rods from Firm Feel, and I sent the guy an email about it but haven't heard back yet. The old struts rods had a hole cross drilled to insert a cotter pin on the front threaded part. The new ones are not cross threaded but they come with jamb nuts. I doubt they will go anywhere.....right?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Assembling the front suspension today. Grease points?
[Re: RapidRobert]
#1616425
05/05/14 01:59 PM
05/05/14 01:59 PM
Pyper70
Athens, Greece
Torsion bar seals are giving me a run for the money...I read the archives and someone suggested installing the rubber seals outside of the car....vertically....I am gonna try that but heat up the seals with a heat gun and a MIG welding glove...
[Re: Pyper70]
#1616426
05/05/14 02:24 PM
05/05/14 02:24 PM
RapidRobert
I'd slide em on the vertical tbar outside the car. I dont know about heating em, I think I'd just use some lube & force it over the hex & trying not to stretch it any more than needed
[Re: wesgtx440]
#1616429
05/07/14 11:43 AM
05/07/14 11:43 AM
Pyper70
Athens, Greece
Hey thanks for that Wes. It's gettin there...I got the torsion bars in and the UCA/LCA installed now its time for the spinle. The UCA is from FirmFeel and I have the Upper ball joint cranked to 150 pounds like its supposed to be but the slot for the cotter pin is barely visible. Should I remove the included washer? I dont think the nut is gonna crank another revolution , its gonna be over 270ft lbs to get this slot open.
The picture is blurry but that dark spot on the castle nut is all thats visible
[Re: Pyper70]
#1616431
05/07/14 12:13 PM
05/07/14 12:13 PM
RapidRobert
You might drill a new hole for the cotter pin or a thinner high grade washer might be an option. For sure dont crank another turn to 270 lbs. Definitely loosen the UCA back up before you set the Tbar height & have it barely snug when you drive it on the rack or make SURE he loosens it, You want the UCA's loose also when YOU set the tbar height. With your weight in barbells in the dr seat set the height to where the wheels/tires look right to YOU in the wheelwells. Tell him not to change the height but he can even it up slightly so both sides are the same height if desired. If you depend on the shop to set the height alot of times they set it too low
[Re: Pyper70]
#1616432
05/07/14 12:38 PM
05/07/14 12:38 PM
Posts: 157 Winlock, Wa
fshd4it
Winlock, Wa
I put FF upper arms on my car this winter and had the same problem. So I called Dick and asked about the washers, he said they are included for a drum brake spindle (which is evidently thinner where the ball joint goes through), and to just leave them off.
In order to know what you want, you'll probably have to find out what you don't want.
[Re: Pyper70]
#1616437
05/07/14 03:57 PM
05/07/14 03:57 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Not sure if you're done yet, but I slide the boots on by placing a socket of similar diameter on the end of the torsion bar ( of course, holding it vertical ), then slid the boot over the socket and then the boot just kept on going over the corners at the end.
Also, make sure you don't tighten the LCA pin nuts until the weight of the car is totally on your torsion bars.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
