Page 1 of 3 1 2 3
5/16 pushrods with solid roller #1616144
05/05/14 01:08 AM
05/05/14 01:08 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Can they be ran? What wall thickness is necessary? Solid roller that will see max of 7500rpms, and there is not enough clearance to the lifter bores for a 3/8 pushrod (A 3/8 will rub the lifter because of my offset intakes)...Is .105 wall sufficient? Do I need .120 wall?
Springs are 250 closed, 600 over the nose, and the pushrods are going to be 7.750" long
What do you guys use or what is safe to use?
Re: 5/16 pushrods with solid roller [Re: mshred] #1616145
05/05/14 01:18 AM
05/05/14 01:18 AM
Washington
skrews Offline
skrews  Offline
Washington
I had Smith Brothers make a set of 5/16 intake and 3/8 exhaust pushrods for my solid roller Indybrock headed motor. Had .712 lift with 245# seat 650# open. Would turn that motor 7300. No issues. Told them to give me the best they could on the intakes.
Re: 5/16 pushrods with solid roller [Re: skrews] #1616146
05/05/14 01:26 AM
05/05/14 01:26 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Any idea on the wall thickness of the 5/16 ones?
Re: 5/16 pushrods with solid roller [Re: mshred] #1616147
05/05/14 01:34 AM
05/05/14 01:34 AM
Washington
skrews Offline
skrews  Offline
Washington
Nope. Just told them I wanted the best on the intakes, although they are likely the same wall thickness intake and exhaust.
Re: 5/16 pushrods with solid roller [Re: skrews] #1616148
05/05/14 09:30 AM
05/05/14 09:30 AM
Guitar Jones Offline
I'm using Trend 5/16 pushrods in my engine .118 wall thickness IIRC.
Re: 5/16 pushrods with solid roller [Re: Guitar Jones] #1616149
05/05/14 01:18 PM
05/05/14 01:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
Smith Brothers 5/16 .120 wall here. 275 on the seat, 600 open. Still going after 225 runs.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 5/16 pushrods with solid roller [Re: Triple Threat] #1616150
05/05/14 02:49 PM
05/05/14 02:49 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
So it looks like a .120" wall thickness 5/16 is probably the best way to go if forced to stay with that size.
Re: 5/16 pushrods with solid roller [Re: mshred] #1616151
05/05/14 02:57 PM
05/05/14 02:57 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Manton makes a nice 11/32" pushrod.
WIZE
In Car:
Re: 5/16 pushrods with solid roller [Re: Streetwize] #1616152
05/05/14 03:05 PM
05/05/14 03:05 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Was just told about these thicker 5/16 push rods. You can buy a variety of stepped and tappered pushrods. If you know you lengths enter that number on eBay and you would be surprised what's out there cheap. I just got some 9/16 8.300 pushrods with long tapper and short tapper for about what you would pay for lash caps lol.
Re: 5/16 pushrods with solid roller [Re: Streetwize] #1616153
05/05/14 03:13 PM
05/05/14 03:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I am not sure even the 11/32 stuff would fit. The 5/16 is already very close to touching the lifter bore
I have heard that too thick of a wall thickness on a small diameter pushrod can actually weaken the design...any truth to this?
Re: 5/16 pushrods with solid roller [Re: Leon441] #1616154
05/05/14 05:39 PM
05/05/14 05:39 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I will check that out!
Wondering if anyone runs less then .120" wall 5/16 stuff and if it works ok
Re: 5/16 pushrods with solid roller [Re: Triple Threat] #1616155
05/05/14 08:03 PM
05/05/14 08:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same set up here on my Rampage
Re: 5/16 pushrods with solid roller [Re: MR_P_BODY] #1616156
05/05/14 08:13 PM
05/05/14 08:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
The nitrous is what slightly worries me about using such a small pushrod...for some reason I am having serious issues pulling the trigger on this- the 5/16 just makes me feel uncomfortable for some reason, but I have no choice at this point
Re: 5/16 pushrods with solid roller [Re: mshred] #1616157
05/05/14 08:43 PM
05/05/14 08:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Spring pressure is spring pressure.. if its strong
enough to hold the rev then the PR will
Re: 5/16 pushrods with solid roller [Re: MR_P_BODY] #1616158
05/05/14 08:53 PM
05/05/14 08:53 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
True
I also wonder if my pushrod issue is because I have a factory roller block with a slightly larger lifter boss, or if everyone has the same issue with the Indy stuff?
Re: 5/16 pushrods with solid roller [Re: mshred] #1616159
05/05/14 09:12 PM
05/05/14 09:12 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am using 11/32 x .120 wall and I am running the 360-2 Indy heads. Mine are 7.605 and 7.640 length Manton pushrods.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 5/16 pushrods with solid roller [Re: D-50] #1616160
05/05/14 09:20 PM
05/05/14 09:20 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
How close are the intake pushrods to the lifter bosses on your setup? Did you open up the pushrod holes in the heads at all to get that size to fit?
Re: 5/16 pushrods with solid roller [Re: mshred] #1616161
05/05/14 09:27 PM
05/05/14 09:27 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I bought the heads used and ported by Brett Miller they were probably clearenced already. I do not remember how close they are to the lifter bosses. I am running a 1973 340 block.
Re: 5/16 pushrods with solid roller [Re: D-50] #1616162
05/05/14 09:28 PM
05/05/14 09:28 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Cool. Are you also running different length intake and exhaust pushrods? or did you get the same length for each?
I hope that 5/16 will be sufficient...I just feel really uneasy about this lol
Re: 5/16 pushrods with solid roller [Re: mshred] #1616163
05/05/14 09:39 PM
05/05/14 09:39 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My intake and exhaust push rods are different lengths.
Page 1 of 3 1 2 3
