Page 1 of 3 1 2 3
Cheap but not ugly upsized wheel options for B-body #1615988
05/04/14 08:18 PM
05/04/14 08:18 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I'm trying to find cheap bigger wheels- new or used, aftermarket or some OEM - to put on my '67 Coronet wagon.
I'd like to stick with 16 or 17 inch wheels to retain some sidewall for comfort.
I've considered some Mustang or Panther wheels but I'm not sure how they work clearance/offset-wise on my car. Most Ford wheels I've seen on A-bodies don't have enough negative offset to not look out of place on a bigger car like mine, IMO.
Same thing with a lot of general aftermarket wheels and even later-model OE Charger/Challenger wheels - too much offset, no rim lip, looks goofy (I've seen B-bodies with the lower-end Challenger blocky five spokes and it doesn't do it for me at all).
This is what my car looks like now on 15s with small hubcaps - I really dig how it looks, but 215/75s...
I like upsized Torq Thrust-type wheels like this... but I also don't want to run straight to Torq Thrusts since everyone and their dog goes for that style at some point.
So my goals are: cheap (around $1000 for a set tops), works with the body style, decent street tire selection. I'm asking because so far I've only been able to figure out what DOESN'T look good, and this particular forum is more open-minded than ye olde Mopar Or No Car hardliners :P
What do you think I should consider? If hub bores or brake rotors need to be trimmed some to fit that's NBD.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615989
05/04/14 09:08 PM
05/04/14 09:08 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
http://www.vintagewheelworks.com/products/wheels
The V40 or V45 would look great on your wagon. 16x7 or 16 x 8 wheel size gets you under $1000 for 4.
Plenty of pics on the website of older cars with their wheels on them check it out.
I don't know what fits in those 66 and 67 B body cars.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615990
05/04/14 09:41 PM
05/04/14 09:41 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I think the American Racing Salt Flat rims would look really good on that car, but they run about $330 each.
These are 17" steel wheels under $200 each. With primer, ready to paint. Paint it white, put a baby moon cap on it and go. http://www.summitracing.com/parts/wvi-14-7712458/overview/
17x7 4.625 in backspacing, should fit your car fine.
225/60-17 are plentiful, fit on a 7" wheel, and are 27.6" tall (about same height as current tire). They have plenty of sidewall and would look good on the wagon. If you want a little less sidewall, the 225s are available in 55, 50, and 45 series.
Do you know the current wheel size and backspacing?
Michael
Plano, Tx
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Cheap but not ugly upsized wheel options for B-body [Re: 68cuda440] #1615991
05/05/14 04:19 AM
05/05/14 04:19 AM
Eugene, Oregon
Eugene, Oregon
Michael
Plano, Tx
I believe they're 15x6s, I only know that they're off of some kind of Dodge truck. They have 3 lobes around the hubcap ring and a smooth inner lug/hub area if that places them at all.
I'm probably going to run at least 235s or 235s/245s at a minimum. 215s are too narrow for a car that weighs two tons that'll be driven the way I want to drive it :P
I do really like those Salt Flat wheels. I've considered them off and on - I'm not sure if they'd still look good keyed white to the car or left gray either way. They do look pretty fitting on 60s cars in 16 inch size:
I also have found a few sets of 2405-style newer wheels for sale. I can't find any recent Mopar wheels on older Mopars (in general) - do any styles from any late 2000s cars look good?
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615992
05/05/14 05:24 AM
05/05/14 05:24 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Coy C5 Wheels are nice and relatively inexpensive.
~ $175.00 each
http://www.coyswheel.com/coys.html
https://picasaweb.google.com/jc78c09
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615993
05/05/14 03:36 PM
05/05/14 03:36 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Motech Performance sells some 17 and 18" Streeter wheels for about $600 a set you can use.
Re: Cheap but not ugly upsized wheel options for B-body [Re: MuuMuu101] #1615994
05/05/14 04:25 PM
05/05/14 04:25 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
I really like the painted wheel/poverty cap look. have you considered having 16 or 17 inch rims mated to your existing centers? can't be that expensive and would look killer.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615995
05/05/14 04:26 PM
05/05/14 04:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Go to www.mhtwheels.com and check out the US Mags offerings. There are some nice wheels at decent prices.
I've dealt with MHT through work for several years. They have good stuff and fair prices.
- Stu Harmon
Re: Cheap but not ugly upsized wheel options for B-body [Re: MuuMuu101] #1615996
05/05/14 05:48 PM
05/05/14 05:48 PM
Eugene, Oregon
Eugene, Oregon
A friend just pointed me to Year One's upsized Rallye wheels:
https://www.yearone.com/Product/wheels/mrw178slvs
What do you guys think? I always thought standard-sized ones wouldn't look quite right on my car but bigger ones might look pretty cool.
Re: Cheap but not ugly upsized wheel options for B-body [Re: pauly v.100] #1615997
05/05/14 05:57 PM
05/05/14 05:57 PM
Eugene, Oregon
Eugene, Oregon
I'd like to be able to keep my current caps if I stay with steelies. The upsized cop rims out there look cool on the blockier 80s cars but I don't like the bigger caps on older Mopars. I really would like to like those upsized Wheel Vintiques smoothies, but I think their look is better suited to kind of greaser/street rod style cars.
If I could find four-slot 17 inch steelies that took my caps that'd be perfect. I could always paint the outer edge of the rim black if they looked too big.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615998
05/05/14 07:17 PM
05/05/14 07:17 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Why are you wanting bigger rims?
I went 17s on one of my wagons and after driving it a summer I wasn't so sure anymore. I live in an urban area with lots of street car tracks, pot holes, bike riders, etc...
felt them all hard.
On my next wagon I stayed with 15" rims looks better feels better
and the car handles great with the help of a bunch of firm feel parts and the 15x7 and 15x8 wheels
245/60,15 front and 275/60,15 rear.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1615999
05/05/14 10:54 PM
05/05/14 10:54 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
You can keep the caps.
http://www.rallyamerica.com/Original_Centered_Wheels.html
Re: Cheap but not ugly upsized wheel options for B-body [Re: boydsdodge] #1616000
05/06/14 06:27 AM
05/06/14 06:27 AM
Eugene, Oregon
Eugene, Oregon
felt them all hard.
245/60,15 front and 275/60,15 rear. [/quote
Tire choices - I'm not autocrossing the thing but I want it to handle. 15 inch tires tall enough for a car this big don't come in very good choices for that. PLus the giant sidewalls don't help much.
Re: Cheap but not ugly upsized wheel options for B-body [Re: pauly v.100] #1616001
05/06/14 06:27 AM
05/06/14 06:27 AM
Eugene, Oregon
Eugene, Oregon
http://www.rallyamerica.com/Original_Centered_Wheels.html [/quote
But I want bigger diameter wheels, not just bigger 15s.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1616002
05/06/14 12:00 PM
05/06/14 12:00 PM
boydsdodge Offline
boydsdodge  Offline
I am using Maxxis Marauder tires.
They have a stiffer side wall and lower tread wear rating then regular M/S tires
also have good sizes.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Secret Chimp] #1616003
05/06/14 09:11 PM
05/06/14 09:11 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Another vote for Coys. They are cast one pieces so no custom offsets but the stock sizes are right for muscle cars. I have about $1000.00 into these incuding the tires. 18x9.5 rear, 17x8 front
Id stay away from any cheap wheel thats chromed. Go polished aluminum. Even if the shine isnt that great you can fix it. Cant fix peelng chrome.
Re: Cheap but not ugly upsized wheel options for B-body [Re: Pool Fixer] #1616004
05/07/14 12:23 AM
05/07/14 12:23 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I am also a fan of the Salt Flats
However I just saw these the other day. Have not checked to see all what is offered
http://www.jegs.com/p/Hurst/Hurst-Dazzler-Wheels/2970945/10002/-1
Re: Cheap but not ugly upsized wheel options for B-body [Re: roadhazard] #1616005
05/07/14 03:34 PM
05/07/14 03:34 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
I have a set of 17" Stockton steelies on my wagon, 17x8 with 245/45/17 in front, and 17x10 with 315/35/17 in back.
They will take the same hubcap your wagon currently has on it.
I've been thinking about making a change, if you're interested let me know.
Mine handles fantastic with bigger t-bars and sway bars f/r. 25mph ramps at 45-50, it just hunkers down and goes.
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Cheap but not ugly upsized wheel options for B-body [Re: jon01] #1616006
05/07/14 08:28 PM
05/07/14 08:28 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I dig steelies... do you have a pic of the 17's?
Re: Cheap but not ugly upsized wheel options for B-body [Re: Pool Fixer] #1616007
05/08/14 11:52 PM
05/08/14 11:52 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
I have JD Wheels, I had them price matched through jegs for $130 a piece for the 17x7s on the front, the 18x8s where $150 each.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Page 1 of 3 1 2 3
