426 hemi fuel line Edebrock carbs? #1615855
05/04/14 01:25 PM
05/04/14 01:25 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Does anyone make a fuel line set for the 426 hemi using the stock inline duad quad manifold and Edelbrock carburetors?
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615856
05/04/14 02:55 PM
05/04/14 02:55 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Tim Banning, For Hemis Only www.forhemisonly.com
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615857
05/04/14 06:33 PM
05/04/14 06:33 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Factory SHOULD lines work ??? , the inlet thread size is the same on the Ebrocks as the original carters
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615858
05/04/14 07:02 PM
05/04/14 07:02 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I bought my line set from Mancini. I'm running eddy's on the factory inline intake everything fit fine.
Re: 426 hemi fuel line Edebrock carbs? [Re: HEMIDOG 70] #1615859
05/04/14 08:58 PM
05/04/14 08:58 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I checked the Mancini web site and noted the fuel lines for the Edelbrock Hemi package states "special fabricated fuel lines". I will need to call them to see if they sell these lines without the complete package. My stock factory fuel lines did not clear the Edelbrock carbs on the passenger side. Thanks for you info.
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615860
05/05/14 10:15 AM
05/05/14 10:15 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
What don't they clear ?
Re: 426 hemi fuel line Edebrock carbs? [Re: JohnRR] #1615861
05/05/14 01:11 PM
05/05/14 01:11 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
The rear carb lines clears both carburetors; but the front carb line does not drop down far enough to cleat the primary and secondary shafts of the front carb. if the front line coming out of the carb would go another inch down toward the manifold it would be to go under the front carb throttle shafts and linkage. Or, if the fuel line came straight out of the carb another couple of inches before it bent down it could clear the carb shafts.
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615862
05/05/14 01:17 PM
05/05/14 01:17 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
In the picture posted by Hemidog it looks like the fuel line of the front carb comes out several more inches than the stock line so when it bends forward it clears the throttle shafts.
Re: 426 hemi fuel line Edebrock carbs? [Re: sbcjd] #1615863
05/06/14 08:53 PM
05/06/14 08:53 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Just be glad that you didn't fall for the "deal" that I bought at the Mopar Nats. A set of Hollys on a Stage V intake. Now you have to MAKE the lines as the Hollies feed on the drivers side. 3 sticks of stainless line later....
