I think my linkage was never set up right. If I put my shifter in "1", it will shift to second before I move the shift lever. It will stay in second until I shift it up to drive.
Does this sound like a simple adjustment on the shifter linkage?
If so can someone talk me through the process of adjusting it?
also when downshifting from drive to second, I can control it with the shifter but shifting from second to first, it will not go into 1st until I come to a complete stop.
It the trans is left in drive, it shifts fines through all three gears on its own.
I have a shift kit and want to see if the car can "chirp" first to second but it shifts to early the way it is now.
