Starter for a 130 tooth flywheel need help!!
#1615753
05/04/14 01:59 AM
05/04/14 01:59 AM
Posts: 60 Sweet Home, Oregon
friesza
Sweet Home, Oregon
I have a friend who is working on a transplanted 440 with a 4 speed....it has the stock bell housing but they installed an aluminum 130 tooth flywheel. He bought an aftermarket mini starter for a 130 tooth from summit but says it is nowhere close to engaging.....is it possible that because the smaller diameter of the new flywheel that maybe an aftermarket bell housing is needed? ....this is the starter... http://www.summitracing.com/parts/cv...engine-type/v8According to ram clutches website a 130 tooth flywheel is12.25" and a 143 tooth is 13.75" O.D.... I have not seen his application just going by the info he gave me.... Thanks...
"Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. It is the right which they first of all strike down."
Frederick Douglass
Re: Starter for a 130 tooth flywheel need help!!
[Re: friesza]
#1615754
05/04/14 02:05 AM
05/04/14 02:05 AM
Posts: 10,168 A Red State
SNK-EYZ
A Red State
It sounds like you probably have a bellhousing for an 11" flywheel.
[Re: Jim_Lusk]
#1615757
05/04/14 09:39 AM
05/04/14 09:39 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
The 143 tooth bells were cast iron, the 130 aluminum. If he goes with a Lakewood scattershield instead of OEM, they come with adapters for 130, 143 and I think the 172 tooth flywheels.
[Re: B5 Bee]
#1615758
05/04/14 11:48 AM
05/04/14 11:48 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
There are also 130 tooth cast iron bellhousings , 68 69 is the only years that had the 143 tooth bellhousings ... in passenger cars ...
The OP does not say as thing as to what the person is working with???
[Re: JohnRR]
#1615759
05/04/14 12:13 PM
05/04/14 12:13 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I agree I have a 130 tooth cast iron bell in the garage.Have a 143 from a 69 thats aluminum and an Ansen scattershield also.Rocky
Chrysler Firepower
[Re: therocks]
#1615761
05/04/14 03:10 PM
05/04/14 03:10 PM
Posts: 768 Ohio
Dan Brewer
Ohio
Have a pic or casting number of the alum 11" bell? Never seen one.
[Re: Cab_Burge]
#1615764
05/04/14 07:12 PM
05/04/14 07:12 PM
JohnRR
1970/71 440-6 paks had eleven inch clutches with aluminum bell housings, same as 426 street hemi probally
All big blocks and hemis in 70/71 used 130 tooth wheels and if they didn't have a 10.5" clutch they would have used a 10.95 scalloped clutch , if the the scalloped was being made back then ???
[Re: Dan Brewer]
#1615766
05/04/14 07:12 PM
05/04/14 07:12 PM
JohnRR
[Re: JohnRR]
#1615767
05/04/14 07:23 PM
05/04/14 07:23 PM
B5 Bee
Pangaea
Does that 130 tooth iron bell have the 4.80" bearing retainer?
[Re: B5 Bee]
#1615768
05/04/14 07:31 PM
05/04/14 07:31 PM
JohnRR
There are also 130 tooth cast iron bellhousings , 68-69 is the only years that had the 143 tooth bellhousings ... in passenger cars ...
No , they are the small retainer , I think 4.35?
[Re: JohnRR]
#1615769
05/04/14 11:30 PM
05/04/14 11:30 PM
Posts: 768 Ohio
Dan Brewer
Ohio
[Re: Cab_Burge]
#1615770
05/04/14 11:54 PM
05/04/14 11:54 PM
Posts: 768 Ohio
Dan Brewer
Ohio
not a true 11". I was refering to the comment about 69 11"/143 bellhousing made of alum.
[Re: Dan Brewer]
#1615771
05/05/14 11:09 AM
05/05/14 11:09 AM
JohnRR
I knew what you were talking about Dan , It was just an FYI for Cab.
