Re: pushrod for power to manual brake conversion
[Re: AMC400Mopar]
#1615174
05/02/14 07:23 PM
05/02/14 07:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks for the tip!
Being that you sold the other rod you pretty much need to buy a adjustable... I make my own but I cut the hoop off of the original and weld it to a 3/8 dia pushrod with the ball end on it... they are hard enough and have plenty of length.. I usually have a pile of them laying around ![](/ubbthreads/images/graemlins/wave.gif)
[Re: AMC400Mopar]
#1615176
05/03/14 12:54 AM
05/03/14 12:54 AM
MR_P_BODY
I like your cut and weld idea, but how do you determine the right length?
I just stick the round end of the push rod in the master and the hoop on the pedal and mark where they would cross.. pull it down, cut and tack it, then check it.. if its right then I weld it up ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1615177
05/03/14 06:28 AM
05/03/14 06:28 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Mancini do an adustable pushrod, ordered 1 this week . Currently hav a ford 150 pushrod trimmed to fit
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
