Main bore size of a 383/400
#1614463
05/01/14 01:27 AM
05/01/14 01:27 AM
Posts: 2,726 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I can't believe with all my Mopar books I can't find the main bore min-max size for a 400. Thanks for your help.
2011 Drag Pak Challenger
Re: Main bore size of a 383/400
[Re: rickseeman]
#1614464
05/01/14 01:52 AM
05/01/14 01:52 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Well the stock-min size for the 400 is 4.342. As for max, less is better. Keep the bores as thick as possible. Dont try to gain CI with the bores.
[Re: Sport440]
#1614466
05/01/14 02:23 AM
05/01/14 02:23 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Don't think that's what he's asking.. Crankshaft..
Chris.
[Re: Chris'sBarracuda]
#1614467
05/01/14 03:23 AM
05/01/14 03:23 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Should be in the service manual and any of the bearing catalogs
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#1614468
05/01/14 11:31 AM
05/01/14 11:31 AM
rickseeman
Stuttgart, Arkansas
Yes, what I need is the main bore spec. An RB is 2.9425-2.943 but I don't have the Chrysler specs for a B engine. Thanks.
[Re: MR_P_BODY]
#1614472
05/01/14 12:55 PM
05/01/14 12:55 PM
rickseeman
Stuttgart, Arkansas
There should be a high and low spec. When line honing 5 main bores at once it would be a little difficult to hit them all at the same time within a tenth.
[Re: rickseeman]
#1614473
05/01/14 12:58 PM
05/01/14 12:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats why I said check other data... this didnt have a max/min.. all the other data on that engine did show max/min
[Re: MR_P_BODY]
#1614474
05/01/14 06:27 PM
05/01/14 06:27 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
I use an old Vandervell bearings catalog (#112) which has most measures in inches and metric. For the B Mopar engine it reads: Main bearing housing 2.8175"-2.8180" Crankpin mains 2.6245" - 2.6255" I have used these measures both for checking/lineboring and crankgrinding and it works out fine; I normally grind the crank at 2.6250 as a base for the undersizes. Hope this helps you out!
