What kind of rwhp does a late 70s; 440 make. Not much #1614419
04/30/14 11:29 PM
04/30/14 11:29 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I dyno'd it while I had the front driveshaft off just for [Email]s@#$[/Email] and giggles.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Uberpube] #1614420
05/01/14 12:16 AM
05/01/14 12:16 AM
Kirkland, Washington
Pacnorthcuda Offline
And what 440 exactly were you thrashing at a mean 3000 rpm for that test?
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Pacnorthcuda] #1614421
05/01/14 12:22 AM
05/01/14 12:22 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No reason to "Beat it" any harder as power dropped off after 3000 rpm.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Pacnorthcuda] #1614422
05/01/14 12:23 AM
05/01/14 12:23 AM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
1978 440 , edelbrock 750 carb dual crush bent exhaust 2 1/4", mopar chrome box , rest stock. 100,000 miles.
It pulled to about 4000 and hit a wall.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Uberpube] #1614423
05/01/14 01:48 AM
05/01/14 01:48 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
1978 440 ,edelbrock 750 carb dual crush bent exhaust 2 1/4", mopar chrome box , rest stock. 100,000 miles.
You probably lost 20hp in that carb vs the stock tq
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: 451Cuda] #1614424
05/01/14 02:17 AM
05/01/14 02:17 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
OPs screen name is really strange.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Kern Dog] #1614425
05/01/14 06:46 AM
05/01/14 06:46 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
That's about what I'd expect out of that package. Less than 8-1 compression to start with.Dave
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: quickd100] #1614426
05/01/14 06:50 AM
05/01/14 06:50 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i would expect that you are itching to try some boost on that kind of package aswell
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: 1Fast340] #1614427
05/01/14 07:18 AM
05/01/14 07:18 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Actually I've got a 74' RamCharger with 79,000 actual miles on it, it's an original 440 D code unit. Steel crank motor too.
I'm still trying to work all the bugs out of the 318 project. Haven't had much time to screw with it lately though.Dave
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: quickd100] #1614428
05/01/14 10:16 AM
05/01/14 10:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I remember pulling a head on my 77 400 to have a burnt valve repaired. Couldn't believe how far that piston was down in the hole at TDC. Thought about throwing some 915's on it, but I don't think that would have even helped.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: J_BODY] #1614429
05/01/14 01:09 PM
05/01/14 01:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I don't buy it, you've got a poor running 440 even by late 70s standards. Thats 180 horsepower and 325 ft lbs of torque. I'd expect that running on 6 cylinders with 27 degrees of total timing. You should have 400ish ft lbs of torque still IMO.
Run a compression test and report back to us.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Kern Dog] #1614430
05/01/14 04:05 PM
05/01/14 04:05 PM
California
mickm Offline
mickm  Offline
California
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: GTX MATT] #1614431
05/01/14 04:28 PM
05/01/14 04:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 74 440 had 230 brake HP @ 4000 rpm.. the HP/police
version had 275 brake HP @4400
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Uberpube] #1614432
05/01/14 04:41 PM
05/01/14 04:41 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Throw some more timing at it?
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Sixpak] #1614433
05/01/14 09:14 PM
05/01/14 09:14 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
It had so much torque it was smoking the tires on the rollers! Look how bad the graph turns into a squiggly line!
Keith
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: Dunnuck Racing] #1614434
05/02/14 02:18 AM
05/02/14 02:18 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I can tell you that with a few right bolt ons...cam, intake, fresh heads, 10"/11" converters, etc...
A 78 untouched short bock went 12.30's @ 110 at 4200#
A 76 untouched short block went 11.70's @ 114 at 3400#
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: GTX MATT] #1614435
05/02/14 06:35 AM
05/02/14 06:35 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
This is also through a transfer case. I would think that robs some power also.
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: viperblue72] #1614436
05/02/14 04:42 PM
05/02/14 04:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I was thinking that as well when I figured 25 percent loss, but how much more can the transfer case really cost?
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: cudadoug] #1614437
05/02/14 05:00 PM
05/02/14 05:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Can we get more details on the '76?
Re: What kind of rwhp does a late 70s; 440 make. Not much [Re: GY3] #1614438
05/02/14 05:37 PM
05/02/14 05:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think a stock 375hp magnum might do 240hp at the rear. an 8:1 '78 smogger was rated at 195hp@3600rpm. figuring at least a 20% loss with a tight converter thats 156hp at the rear, maybe a little less in the real world.
