What kind of rwhp does a late 70s; 440 make. Not much
#1614419
05/01/14 12:29 AM
05/01/14 12:29 AM
Posts: 728 Southern Alberta
Uberpube
Southern Alberta
I dyno'd it while I had the front driveshaft off just for [Email]s@#$[/Email] and giggles.
Re: What kind of rwhp does a late 70s; 440 make. Not much
[Re: Pacnorthcuda]
#1614421
05/01/14 01:22 AM
05/01/14 01:22 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
And what 440 exactly were you thrashing at a mean 3000 rpm for that test?
No reason to "Beat it" any harder as power dropped off after 3000 rpm.
[Re: Pacnorthcuda]
#1614422
05/01/14 01:23 AM
05/01/14 01:23 AM
Uberpube
Southern Alberta
1978 440 , edelbrock 750 carb dual crush bent exhaust 2 1/4", mopar chrome box , rest stock. 100,000 miles. It pulled to about 4000 and hit a wall.
[Re: Uberpube]
#1614423
05/01/14 02:48 AM
05/01/14 02:48 AM
Posts: 345 Nebraska
451Cuda
Nebraska
1978 440 ,edelbrock 750 carb dual crush bent exhaust 2 1/4", mopar chrome box , rest stock. 100,000 miles. It pulled to about 4000 and hit a wall.
You probably lost 20hp in that carb vs the stock tq
[Re: quickd100]
#1614426
05/01/14 07:50 AM
05/01/14 07:50 AM
Posts: 2,578 sweden
1Fast340
sweden
That's about what I'd expect out of that package. Less than 8-1 compression to start with.Dave
i would expect that you are itching to try some boost on that kind of package aswell
[Re: 1Fast340]
#1614427
05/01/14 08:18 AM
05/01/14 08:18 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Actually I've got a 74' RamCharger with 79,000 actual miles on it, it's an original 440 D code unit. Steel crank motor too. I'm still trying to work all the bugs out of the 318 project. Haven't had much time to screw with it lately though.Dave
[Re: J_BODY]
#1614429
05/01/14 02:09 PM
05/01/14 02:09 PM
Posts: 5,169 CT
GTX MATT
CT
I don't buy it, you've got a poor running 440 even by late 70s standards. Thats 180 horsepower and 325 ft lbs of torque. I'd expect that running on 6 cylinders with 27 degrees of total timing. You should have 400ish ft lbs of torque still IMO. Run a compression test and report back to us.
[Re: Kern Dog]
#1614430
05/01/14 05:05 PM
05/01/14 05:05 PM
Posts: 4,179 California
mickm
California
OPs screen name is really strange.
[Re: Uberpube]
#1614432
05/01/14 05:41 PM
05/01/14 05:41 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Throw some more timing at it?
[Re: GTX MATT]
#1614435
05/02/14 07:35 AM
05/02/14 07:35 AM
Posts: 2,141 junction city oregon
viperblue72
This is also through a transfer case. I would think that robs some power also.
[Re: cudadoug]
#1614437
05/02/14 06:00 PM
05/02/14 06:00 PM
Posts: 4,715 Wichita
GY3
Wichita
I can tell you that with a few right bolt ons...cam, intake, fresh heads, 10"/11" converters, etc...
A 78 untouched short bock went 12.30's @ 110 at 4200#
A 76 untouched short block went 11.70's @ 114 at 3400#
Can we get more details on the '76?
[Re: GY3]
#1614438
05/02/14 06:37 PM
05/02/14 06:37 PM
Posts: 3,916 usa
lewtot184
usa
i think a stock 375hp magnum might do 240hp at the rear. an 8:1 '78 smogger was rated at 195hp@3600rpm. figuring at least a 20% loss with a tight converter thats 156hp at the rear, maybe a little less in the real world.
