Power Steering #1614281
04/30/14 08:12 PM
04/30/14 08:12 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I was just at the alignment shop, and when he turned the wheel either with the steering wheel or the tires with the eng off it would puke fluid back up through the cap on the pump. I don't ever remember seeing this back in the day.
Also when you move the steering wheel back and forth a little the input shaft will walk in and out a little. Is that normal?
Re: Power Steering [Re: 71birdJ68] #1614282
04/30/14 11:51 PM
04/30/14 11:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Over filled on the puke back and normal on the shaft walk.
Re: Power Steering [Re: stumpy] #1614283
05/01/14 12:18 AM
05/01/14 12:18 AM
Morristown Tn.
Morristown Tn.
Thank you.
