Re: Edelbrock Thunder Series
[Re: VegasCharger]
#1614230
04/30/14 05:53 PM
04/30/14 05:53 PM
RapidRobert
edelbrock #1843 (10.97 + the ride) plus the horizontle OE mopar throttle pin/nut from the AVS. Yes the adapter is needed. The adapter bolts to the side linkage flange then then reuse your OE horizontle throttle pin on the adapter then the throttle cable slips on the inside edge of the pin just like OE. Your OE intake is a square bore & I'm assuming that carb is also so you're good there. EDIT You might consider converting the LEAN (emission regs in those days were strict/discombobulated) OE '68 AVS to eddy 2 step rods/shorter pri jets to richen it up for more driveability especially since this is a stock 383. MORE EDIT I just priced it & you'll be into this over 4 bills. Just me I would definitely richen the OE AVS instead. I had an OE AVS on a 68 GTX 440 & it was doggy till I swapped on a 67 AFB. This was back in '75 & they didn't have what they have now & it woke it up to a certain extent
[Re: burdar]
#1614232
04/30/14 07:08 PM
04/30/14 07:08 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Also, consider a 5/16" insulating carb base gasket. A lot of intake heat can transfer to the carb. This is particularly important since you live in Vegas. You'll need to keep the carb as cool as possible.
This is a good idea , these carbs need a little isolation , and yes you need the throttle lever adaptor bracket.
[Re: JohnRR]
#1614233
04/30/14 07:11 PM
04/30/14 07:11 PM
Posts: 4,179 California
mickm
California
i'm not aware of that gasket, and have looked. can someone throw out a part number or a link?
[Re: RapidRobert]
#1614235
04/30/14 10:26 PM
04/30/14 10:26 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: burdar]
#1614236
04/30/14 10:41 PM
04/30/14 10:41 PM
bee1971
Sobieski Wi
Nothing beats this then for the 383/400 - As long as your not concerned about the factory heat choke
Heat Crossover Block Off Plates Built In
http://www.summitracing.com/parts/fel-1214/overview/
http://www.jegs.com/i/Fel-Pro/375/1214/10002/-1
[Re: VegasCharger]
#1614238
05/01/14 12:46 AM
05/01/14 12:46 AM
bee1971
Sobieski Wi
Yellow Arrow Left Is Ported Vacuum - Above The Throttle Plates - Hook Your Dist Vacuum There - Same For Points And Electronic Ignition Dist
Red Arrow Right Is Full Vacuum - Below The Throttle Plates
[Re: bee1971]
#1614241
05/01/14 01:43 AM
05/01/14 01:43 AM
RapidRobert
#1843 black $10.97. #1481 gold $9.97 (Summitt). $13.99 and $11.99 at Jegs.
[Re: RapidRobert]
#1614243
05/07/14 07:25 AM
05/07/14 07:25 AM
Posts: 367 Akron, Ohio
VegasCharger
Akron, Ohio
1/4" on the Felpro. The black one is 5/16" but has no part number & I dont remember the brand/part #
Can you use this type of gasket on my stock '68 383 manifold (2806301)? I'm using Edelbrock #9265 which is a 5/16" (0.320) thick open base gasket, similar to the one you have pictured. Manual says to only use on open plenum manifolds. Or should I use one similar to my original gasket when I removed my Carter AVS (see pic)?
Thanks in advance
