Re: spraying on the tranbrake [Re: hvyweight] #1614060
04/30/14 02:35 PM
04/30/14 02:35 PM
michigan
64ssmax Offline
64ssmax  Offline
michigan
Who's doing it and how much?
thanks
Mike
Mike, the only guys I know that do that are with the turbo cars. I've seen about 150 hp to 250hp shot commonly used. They use the NOS to bring up boost quicker so they dont get caught with there pants down staging. You might want to head over to yellow bullet and see if anyone else has tried what your asking. In my opinion this is the wrong board for this question. You can tell by the types of replys you get back from some of the people here.
By the way nice looking car!
Brian
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: spraying on the tranbrake [Re: 64ssmax] #1614061
04/30/14 03:00 PM
04/30/14 03:00 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
thanks
Mike
Brian
Yes post this over on the bullet......then take cover!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: spraying on the tranbrake [Re: Monte_Smith] #1614062
04/30/14 03:22 PM
04/30/14 03:22 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Monte - you have a PM.
Re: spraying on the tranbrake [Re: Airwoofer] #1614063
04/30/14 05:58 PM
04/30/14 05:58 PM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
I was just curious if anyone was doing it. Currently I feel the car is a little lazy on the 60ft. To date the best was a. 1.25 with an average of 1.28. We went 8.20 at almost 169 mph. I figured if the 60s were in the teens I might see a 7 out of it.
Mike
Re: spraying on the tranbrake [Re: hvyweight] #1614064
05/01/14 01:19 AM
05/01/14 01:19 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Mike
That's a REALLY soft 60ft for a potentially 7 sec car. Something is for sure lacking. Converter, gearing, shocks, set up, tire........something is amiss.
If it's the Cuda in your sig.........it appears to have a LOT of bite in the chassis. You are barely out of the beams and it is punishing the tire and riding the bars hard
Monte
Re: spraying on the tranbrake [Re: Monte_Smith] #1614065
05/01/14 08:52 PM
05/01/14 08:52 PM
johnmilner Offline
johnmilner  Offline
two plates on a 76 duster, late 90s friends car,
9.80 on motor, 8.16 on nos. 1st stage 1 tenth delay, second stage on side of air shifter 2nd gear activated.
400 hp total nos. plates stacked.
Re: spraying on the tranbrake [Re: bigtimeauto] #1614066
05/02/14 03:24 PM
05/02/14 03:24 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
thanks
Mike
Brian
I don't know any personally but I hear some guys spray to spool.
Re: spraying on the tranbrake [Re: BobR] #1614067
05/02/14 04:10 PM
05/02/14 04:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
There is no reason to do this. Some no's combos are tuned fat either on motor or no's and both. This will make it lazy leaving. Some relays are slow releasing delaying the nitrous activation. Look up the drop away time. Some relays come with a diode across the coils to help the magnetic field in the relay's coil collapse faster. Any realistic amount of no's activated while on the brake would be harmful.
