Door problem #1613981
04/29/14 11:30 PM
04/29/14 11:30 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I have a 71 B body, and when the door is closed, I can push, and pull it in and out. Even when driving I can watch it move in, and out. It's way to much, and I have tried moving the striker to every position without any improvement. Would this be a wore out latch, or something? Both doors do it, but driver side is worse.
Re: Door problem [Re: 71birdJ68] #1613982
04/30/14 01:07 AM
04/30/14 01:07 AM
Check the front hinges and pins for wear and movement I'm assuming you have the rubber insulators in place, correct? If not they may help
Re: Door problem [Re: Cab_Burge] #1613983
04/30/14 01:22 AM
04/30/14 01:22 AM
Morristown Tn.
Morristown Tn.
The front hinges are ok. Yes the bumpers are inlace. The latch just isn't holding it in place for some reason.
Re: Door problem [Re: 71birdJ68] #1613984
04/30/14 11:36 AM
04/30/14 11:36 AM
pa.
dan9 Offline
dan9  Offline
pa.
Check the striker post on the door jamb. Maybe the ring is loose on the post.
Re: Door problem [Re: dan9] #1613985
04/30/14 02:15 PM
04/30/14 02:15 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
or striker worn out.
Re: Door problem [Re: 5carguy] #1613986
04/30/14 03:48 PM
04/30/14 03:48 PM
Morristown Tn.
Morristown Tn.
I went and checked the striker out, it don't seem worn.
Re: Door problem [Re: 71birdJ68] #1613987
04/30/14 05:18 PM
04/30/14 05:18 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Without any detail pictures from you we'll all be guessing at the cause.
If you have your weather strip properly installed and your door bumpers in place the next thing is to see if your strikers are worn out.
Are the strikers original? E-Bay junk? NOS?
Are your latches tight in the doors???
So with all that checked and perfect the only thing left is to move the striker in till you can't get the door to catch it, then slowly start moving in out till it catches nicely without slamming.
After ALL of that is checked and adjusted your latches are the only piece of the puzzle left but highly unlikely.
Ron
