Gas tank restoration #1613928
04/29/14 09:45 PM
04/29/14 09:45 PM
Tropicalcats Offline OP
Anybody use this process? I am looking to restore my 70 Challenger gas tank. Mostly surface rust. Just want yo be sure when I put it back in the car it function properly. The car has set for over 20 years and not sure, but more than likely it was left with gas in the tank.
Re: Gas tank restoration [Re: Tropicalcats] #1613929
04/29/14 09:55 PM
04/29/14 09:55 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
What process?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Gas tank restoration [Re: FJR doc] #1613930
04/29/14 10:03 PM
04/29/14 10:03 PM
Re: Gas tank restoration [Re: Tropicalcats] #1613931
04/29/14 10:21 PM
04/29/14 10:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like they boil them out and coat them with black stuff? That's not "restored" that's "fixed" (at best).
Re: Gas tank restoration [Re: ScottSmith_Harms] #1613932
04/29/14 10:43 PM
04/29/14 10:43 PM
So who restores?
Re: Gas tank restoration [Re: Tropicalcats] #1613933
04/29/14 10:45 PM
04/29/14 10:45 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Sorry
http://www.gastankrenu.com
I had them "renu" a gas tank for a Charger that I owned years ago. Like it has been stated, they line the inside and outside with a black coating. Personally, I found it to be a hassle - if you do ship the tank through UPS, it has to be perfectly cleaned with no gas smell. I won't even explain why I know this...lol.
If you have to keep the tank, maybe they can line just the inside and you can do a correct cosmetic restoration on the exterior? When I had it done, I didn't have a choice. Either coat it all or forget it.
Personally, I would have it hot tanked at an old-school radiator or engine shop first.
Re: Gas tank restoration [Re: Tropicalcats] #1613934
04/29/14 10:45 PM
04/29/14 10:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know of any company that properly restores gas tanks (with the original galvanized finish, etc.)
Re: Gas tank restoration [Re: ScottSmith_Harms] #1613935
04/29/14 10:57 PM
04/29/14 10:57 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
You can try Bill @ BMCUDA.COM - give him a call. He's completed an extensive research process on proper galvanizing for Mopars and developed a process to replicate the original galvanizing. The problem with duplicating the original galvanizing: lead was used in the process, in order to get the proper finish. Though, he's been able to use something else that works pretty well.
Re: Gas tank restoration [Re: 1972CudaV21] #1613936
04/29/14 11:32 PM
04/29/14 11:32 PM
So if I bought a new tank are the 70-74 Challengers the same? Except for the ECS of course.
Re: Gas tank restoration [Re: Tropicalcats] #1613937
04/29/14 11:41 PM
04/29/14 11:41 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
70 without ECS - single vent nipple
70 with ECS and 71 - multiple vent nipples at the side
72 may be the same as 71
73-4 have the multiple vent nipples at the front
Buy a new Spectra Premium tank for under $200 and call it a day
Re: Gas tank restoration [Re: YYZ] #1613938
04/30/14 07:46 AM
04/30/14 07:46 AM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
FWIW, I had the tank in my '52 Plymouth done by Gas Tank Renu in 1995 and it's still fine. The tank had major rust and holes before they fixed it.
Re: Gas tank restoration [Re: Tropicalcats] #1613939
04/30/14 09:05 AM
04/30/14 09:05 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Like said getting it galvanized is the tough part.
If you want the outside galvanized then a repo is the only option I know of. And even the repos are a little different than the originals galvanizing.
Look inside it, is there rust? If so trash it and get a new repo for a E body since they are easy to get a repo for.
I have reused several used original tanks because there was no rust inside. I media blasted the outside to get the rust off and painted it with Eastwood Tank Tone paint. Looks OK IMO. I would recommend a light silver color(like Tank Tone) over black if one was to paint there gas tank. IMO black absorbs more heat from the pavement than a lighter color.
I recently blasted one and painted it, didn't cost me anything as I already had the blaster and the paint.
Rusty outside.
But very clean inside.
Ready for paint.
Re: Gas tank restoration [Re: YYZ] #1613940
04/30/14 12:50 PM
04/30/14 12:50 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
You'll be time and money ahead.
Re: Gas tank restoration [Re: Sixpak] #1613941
04/30/14 06:29 PM
04/30/14 06:29 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
gas tanks are / were not galvanized.
they are / were Niterne coated( sp ck ?)
https://board.moparts.org/ubbthreads/show...amp;Search=true
Enjoy life today, It has an expiration date
Re: Gas tank restoration [Re: gtx6970] #1613942
04/30/14 07:21 PM
04/30/14 07:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok Bill......That process, but either way, not available right?
Re: Gas tank restoration [Re: ScottSmith_Harms] #1613943
04/30/14 07:51 PM
04/30/14 07:51 PM
KY
Telvis Offline
Telvis  Offline
KY
I used one of the POR 15 tank restoration kits. It worked great.
That's King Weenie to you!
Re: Gas tank restoration [Re: ScottSmith_Harms] #1613944
04/30/14 09:30 PM
04/30/14 09:30 PM
gtx6970 Offline
gtx6970  Offline
To the best of my knowledge,,,No.
But to be honest I've never dug into it to ck either( my shop client base is more than happy with a repop tank)
Friend of mine has a real Nos 1970 Challenger tank. Next time I see him and see if I can get a few pictures of it
Re: Gas tank restoration [Re: gtx6970] #1613945
04/30/14 10:11 PM
04/30/14 10:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a real NOS Duster tank now, I agree, it's not galvanized (like muffler shields, license plate holders, disc brake backing plates, etc.) similar looking but without the blotches of light and dark zinc particles.
Re: Gas tank restoration [Re: gtx6970] #1613946
04/30/14 11:39 PM
04/30/14 11:39 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have an NOS Challenger 1970 gas tank
Re: Gas tank restoration [Re: gtx6970] #1613947
04/30/14 11:41 PM
04/30/14 11:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think the material was probably TERNE which was a trade name of a lead - nickel coated material. It's no longer made in the US but there is a mill in Japan that still makes it.
