T/A fast ratio steering gear want to turn right???
#1613903
04/29/14 09:48 PM
04/29/14 09:48 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
It is powersteering and if off the ground or revved the wheel will cycle to the far right. The alignment is set with a little too much caster but even and I run the tires at 30 lbs, 215/70/15s. Everything else int hte steering seems to work and drive fine although I have to get use to the fast ratio when I first get hit the road. I know it has a powersteering control valve but it doesn't seem to be adjustable or at least I cant see/found how to adjust it, the valve doesn't slide it only has one position.
Any help/suggestions appreciated, Kevin
Careful, your character's showing!
Re: T/A fast ratio steering gear want to turn right???
[Re: screamindriver]
#1613905
04/29/14 10:15 PM
04/29/14 10:15 PM
mopar346
Thank you, I had seen a similar thread when I searched lst week but since I didn't see slotted holes on mine I decided it was different. I have to ask, wont I loose fluid when running it loose? I realize I only have to loosen it slightly but it is under a lot of pressure and of course my car is fresh. I know wha wha.
Thanks again, I'll try it tomorrow.
[Re: mopar346]
#1613906
04/29/14 10:28 PM
04/29/14 10:28 PM
Posts: 18,160 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1613907
04/29/14 10:35 PM
04/29/14 10:35 PM
mopar346
Now that is worth saving, thank you!
[Re: mopar346]
#1613908
04/29/14 10:43 PM
04/29/14 10:43 PM
Posts: 4,467 Morristown Tn.
71birdJ68
Morristown Tn.
It shows that in the service manual.
[Re: 71birdJ68]
#1613909
05/04/14 12:16 AM
05/04/14 12:16 AM
mopar346
Finally got around to adjusting the control valve today. Did as shown in Dayclona's post, worked like a champ. For the record it was steering right and I tapped it forward until it corrected the issue.
Thanks for help folks.
