Re: 489 pinion shims
[Re: roadrunnerreds]
#1613661
04/29/14 07:51 PM
04/29/14 07:51 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
this might help
PINION SHIM VS. RATIO CHART GEAR RATIO SHIM THICKNESS 3.23-0.015 , 3.55-0.015 , 3.73-0.014 , 3.90-0.013 , 4.11-0.012 , 4.30-0.011 , 4.56-0.010
got this from a Car Craft item I think
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1613663
04/29/14 08:53 PM
04/29/14 08:53 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I really doubt if you can predict a pinion depth shim based on the gear ratio.
[Re: Cab_Burge]
#1613665
04/30/14 04:22 PM
04/30/14 04:22 PM
John_Kunkel
Rio Linda, CA
You don't need a crush sleeve to set the pinion preload when setting it up, only after the correct pinion depth is determined do you actually need to install a crush sleeve or spacer.
