65 belvedere 383 swap #1613353
04/28/14 11:48 PM
04/28/14 11:48 PM
San Jose ca
70b7duster Offline OP
San Jose ca
Just pulled out the poly 318 and cable shift trans, and installed the 383 w/ a later 727. The trans mount doesn't line up. Do I need a 66 and later trans mount?
Re: 65 belvedere 383 swap [Re: 70b7duster] #1613354
04/29/14 01:11 AM
04/29/14 01:11 AM
Probally need the later tranny cross member It has been a while since I've done the early B body to later 727 swap, I'm almost positive you need the later tranny crossmember to make it bolt in and work with no other mods except maybe drilling two new holes in the later cross member and maybe sltting one side of the new cross member to seat up to your exeisting tranny subframes That may be on the A bodys though, to many swaps to long ago
Re: 65 belvedere 383 swap [Re: Cab_Burge] #1613355
04/29/14 01:15 AM
04/29/14 01:15 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I replaced a Poly 318 cable shift set up in my '65 Belvedere with a 440 and later model 727 using Schumacher mounts. Everything else fit when I used those mounts.
Re: 65 belvedere 383 swap [Re: 70b7duster] #1613356
04/29/14 01:32 AM
04/29/14 01:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did you use the same trans rubber mount off the 65 trans? What engine mounts did you use? I have a 64 and everything bolted right back up. How far is it off? Did you swap to a later k-frame?
Re: 65 belvedere 383 swap [Re: cudaman1969] #1613357
04/29/14 09:56 AM
04/29/14 09:56 AM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
Early B-Body Polyurethane Conversion Tranny Mount
Converting an early B-Body to a '66 or newer tranny just got a lot easier — thanks to our new conversion tranny mount that eliminates the need for cross-member fabrication. Made with high-quality polyurethane, our new tranny mount offers durability that far surpasses the Chrysler original.
Re: 65 belvedere 383 swap [Re: Joesixpack] #1613358
04/29/14 09:56 AM
04/29/14 09:56 AM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
Re: 65 belvedere 383 swap [Re: Joesixpack] #1613359
04/29/14 11:27 AM
04/29/14 11:27 AM
San Jose ca
San Jose ca
I used the schumaker mounts. Nothing else was changed. The trans is out of a 68 Chrysler Newport I believe. It still has the single wire neutral safety switch but is not cable shifter. Thanks for the replies.
Re: 65 belvedere 383 swap [Re: 70b7duster] #1613360
04/29/14 11:31 AM
04/29/14 11:31 AM
San Jose ca
San Jose ca
Looks like I'll be ordering their trans mount now. Thanks for the info.
Re: 65 belvedere 383 swap [Re: 70b7duster] #1613361
04/29/14 11:41 AM
04/29/14 11:41 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Used the Schumacher conversion mount in my '63 and it works perfectly!
