Re: Is my battery dead?
[Re: Got2Gnow]
#1613288
04/28/14 09:51 PM
04/28/14 09:51 PM
RapidRobert
I'd slow charge it overnight (6A) & report back. but your saying it kicks the charger off pretty much immediately with a fault indication?
[Re: Got2Gnow]
#1613290
04/28/14 09:59 PM
04/28/14 09:59 PM
Challenger 1
Cincinnati, Ohio
Went out to start my Dart yesterday and got the dreaded "click". Tried to jump it with my Neon. Put the cables on it and turned over about half a revolution then "click". Let the Neon run for a while to let it "charge". Turned the key and "click". Borrowed a 2A/6A/10A charger and connected it to the battery. Plugged it in and pressed the 2A charge button. The charger then automatically shut off "FAULT" after about 2 seconds. Is it time for a new battery? Is it possible for a battery to be that dead that quick? And yes all connections are clean and tight.
It sounds like dirty connections to me. You sure there clean and tight? If so...
Then the battery is junk. What's the volt meter say that you have hooked up to the battery for testing when you try to crank it?
[Re: RapidRobert]
#1613291
04/28/14 10:11 PM
04/28/14 10:11 PM
Posts: 64 Detroit
Got2Gnow
Detroit
Yes, the charger immediately shuts off and illuminates the "FAULT" LED.
[Re: Challenger 1]
#1613292
04/28/14 10:13 PM
04/28/14 10:13 PM
Posts: 64 Detroit
Got2Gnow
Detroit
Yes, the connections are clean and tight. Unfortunately, I have no meter to measure during crank.
[Re: RapidRobert]
#1613295
04/29/14 12:58 PM
04/29/14 12:58 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Disconnect the terminals and clean the posts, leave the wires off and slowly charge with a 1/2 amp charger for at least 24 hours. If it doesn't charge , its toast. If you don't have a 1/2 amp charger Harbor Freight has them on sale starting 5-01-14 for about 6 dollars and they work great. I use them on the race car during the week, my motor home, and tractor. Like I said leave the wires disconnected when a battery is "super dead"
[Re: pittsburghracer]
#1613296
04/29/14 01:02 PM
04/29/14 01:02 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
To add to the above post I bought my Mothers 2003 chevy malibue when she passed away in 2009 and the stock battery was totally dead twice from my sister leaving the glove box open. I brought it back both times and I am still using the 11 year old battery.
[Re: Sxrxrnr]
#1613299
04/29/14 03:13 PM
04/29/14 03:13 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Most battery chargers are unable to recharge a completely dead battery. The dead battery to the charger shows as no battery hooked to it and the charger refuses to try to charge. Check out Optima(there are others) whose chargers can deal with this.
You also may try hooking up a fully charged good battery in parallel using jumper cables to the failing battery(negative to negative and positive to positive) and let this set for a few hours. This will transfer energy from the good battery to the failed one. You then may find that your failed battery has regained its mojo and then your charger will happily charge it to full capacity. I would try this before considering it doomed
Check voltage on your battery. If under 10 1/2 volts, it will not accept a charge from most consumer type chargers. If so again,,,hook a fully charged battery in parallel as outlined before all should be well. If your dead battery should get excessively warm, this likely suggests an internal short and battery is probably beyond recovery.
Always wear proper eye protection when dealing with auto batteries,,,,a blown up battery is quite a sight to behold.
