Electrical Geniuses Help
#1613239
04/28/14 04:35 PM
04/28/14 04:35 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My '56 Plymouth has a single turn signal indicator in the dash, it was originally powered by a 3-prong turn signal flasher in which one prong powered the T/S indicator lamp. My current aftermarket fuse panel only accepts the typical 2-prong flasher so I can't use a 3-prong flasher.
I'm thinking the only way to make this work is by way of a couple of diodes to allow two inputs to power the single bulb (grounded at the dash). Am I missing any alternatives?
Re: Electrical Geniuses Help
[Re: John_Kunkel]
#1613240
04/28/14 05:29 PM
04/28/14 05:29 PM
RapidRobert
Definitely not a genius but I gotta make a stab at it especially after all the tranny tech Q's you've helped me thru. A 2 terminal (std type) flasher. Fire gets fed to the "in" terminal when your raise or lower the stalk then the "out" terminal flashes intermittently. If you T'd into the "out" terminal wire & ran that to the indicator light wouldn't the light be flashing anytime the flasher can is activated which is what you are after. The indicator light would blinking for a R or a L turn
[Re: OzHemi]
#1613243
04/28/14 07:29 PM
04/28/14 07:29 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
early VW's had the single turn signal indicator in the speedo cluster too. lots of inexpensive parts are avail reman for the 12 and 6 volt systems. I'm sure it wouldn't be too difficult to adapt that part (flasher) to your custom harness. VW's are very simply wired and schematics are avail online. Hope this might help.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: 68HemiB]
#1613249
04/28/14 09:09 PM
04/28/14 09:09 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Makes sense to me IF a '56 is wired like a later model vehicle.
At a glance, one would think that this would work. Alas, that thought process overlooks the fact that a signal flasher is merely a low-load circuit breaker that is normally closed. Hooking an indicator bulb to the output side of the flasher would result in either a solid indicator (if the load was insufficient to make the flasher "flash"), or a perpetually flashing indicator.
My thoughts also go toward a diode solution. Or a pair of bulbs under the single indicator lens. Or a trick, two-filament indicator bulb.
On all the cars I worked with from 1972 and on the plastic flashers were like that and the factory put the plastic flasher in the turn signal circuit. But all the metal flashers were different and the factory put them in the 4 way flasher circuits. But over the years the metal ones also got put into the turn signal circuits. My dealer did not even stock the plastic ones so all cars got the metal ones when the flasher was replaced. The metal ones have a set of contacts that are normally open and then they have a winding tied across it. Whent the turn signal bulbs ground it the winding heats up and bends together so they make contact touch and turn the bulbs on. Once they make contact no current goes thru the winding and it cools and opens the contacts back up. Its easy to tell which kind it has as the plastic ones as you described will lite as soon as the turn signal switch is turned on. The bulbs will lite right away and on the metal type I described when the turn signal switch is turned on the bulbs wont lite right away. They will take a second or two before the bulbs lite up as thats about how long the winding takes to heat up and close the contacts. Ron
[Re: John_Kunkel]
#1613250
04/28/14 09:10 PM
04/28/14 09:10 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
(I hope the flasher prongs are the same as spade connectors)
I did something similar once, and I had some female spade terminals around that fit well on the flasher...so probably not anything exotic sized.
[Re: 68HemiB]
#1613251
04/28/14 09:13 PM
04/28/14 09:13 PM
OzHemi
Garden Grove, CA
I was almost going to suggest a twin fillament bulb too, but went with the rewire idea instead...seemed like a more simple solution.
As for diodes...those seem like a pretty one direction reply.
[Re: John_Kunkel]
#1613256
04/29/14 05:26 PM
04/29/14 05:26 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
John do you want to keep it looking pure stock.Ive seen just the indicators on Ebay.You could add another one.That would be the easiest thing. Rocky
Chrysler Firepower
[Re: therocks]
#1613257
04/29/14 07:03 PM
04/29/14 07:03 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Not a genius, here is the innards of the original:
Diode should work.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
