Automatic race car will not roll easily- trans issue? #1612748
04/27/14 05:34 PM
04/27/14 05:34 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
When we turn the yoke of the rear it moves free. When turning the disconnected driveshaft it is a "Mother".
What is the cause and I assume it is killing et?
Trans is fresh and otherwise works as it should.
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612749
04/27/14 06:51 PM
04/27/14 06:51 PM
okla.
sam64 Offline
sam64  Offline
okla.
that's just the nature of a 727.it will push easier backwards than forward.
Re: Automatic race car will not roll easily- trans issue? [Re: sam64] #1612750
04/27/14 08:12 PM
04/27/14 08:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Other way around, it pushes easier forward.
Re: Automatic race car will not roll easily- trans issue? [Re: John_Kunkel] #1612751
04/27/14 09:23 PM
04/27/14 09:23 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Forward is much easier than backwards on mine.
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612752
04/28/14 12:50 AM
04/28/14 12:50 AM
If your trying to turn the driveshaft or the driveshaft yoke backwards a good rear spraque will be harder to turn backwards, like in reverse, than it will turn going forwards If it turns hard or easy both ways take the tranny apart and look at the rear spraque
Re: Automatic race car will not roll easily- trans issue? [Re: Cab_Burge] #1612753
04/28/14 10:00 AM
04/28/14 10:00 AM
Phila Pa
Phila Pa
Does this cost et? Is this something that isn't a issue when the car is running in gear?
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612754
04/28/14 12:54 PM
04/28/14 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The rear sprag holds the rear drum from spinning in first gear only. after the trans shifts to second the drum spins in the opposite direction and the only friction loss would be from the drag of the fluid that is in between the rollers and races.
Does it cost ET ???
I could come up with a silly idea to make it a non issue, but you'd have an explosion waiting to happen, so I won't.
Something else to check [Re: JohnRR] #1612755
04/28/14 02:17 PM
04/28/14 02:17 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Here's a personal experience condition You can check: Put the car up on jackstands and remove driveline. Rotate pinion and check for ease of rotation both directions. Next pull axles out of pumpkin and notice if on subsequent reinstallation the bearings slide easy or align with the bearing flanges. My 9" axle bearing plates had moved from all the abuse of racing and were contributing to the gawd awful condition of "this '!#$#$234ng' thing is too hard to push!". Noticed car slowing down as well so it might not be the transmission. Something else to check.
Re: Something else to check [Re: Dduster] #1612756
04/28/14 04:37 PM
04/28/14 04:37 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i had the rear support galled up in my trans, it was to the point where i couldn't move the car at all trying to push it. I put in a roller rear support in its place
Re: Something else to check [Re: Dduster] #1612757
04/28/14 04:47 PM
04/28/14 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Drive shaft was disconnected and he was turning the
diff yoke then the drive shaft(the rear end was fine)
Re: Something else to check [Re: MR_P_BODY] #1612758
04/28/14 08:10 PM
04/28/14 08:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Again, depends on which way you're trying to turn the disconnected DS; looking from from the rear, it should turn easier in the counterclockwise direction than in the clockwise direction. If it turns equally hard in both directions it might be worth worrying about.
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612759
04/28/14 08:28 PM
04/28/14 08:28 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Of course it does. Anything that makes the car hard to roll, takes power to overcome that drag.
Monte
Re: Automatic race car will not roll easily- trans issue? [Re: Monte_Smith] #1612760
04/29/14 11:38 AM
04/29/14 11:38 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My car also rolls really hard. Ever since I built the car it has seemed really hard to push, like impossible by myself. I know when I try turning and rolling the spool binds up but even straight it rolls really hard.
67' charger 499 RB 10.57 at 127
Re: Something else to check [Re: John_Kunkel] #1612761
04/29/14 02:18 PM
04/29/14 02:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
^^^^ This ...
Re: Automatic race car will not roll easily- trans issue? [Re: dragram440] #1612762
04/29/14 04:49 PM
04/29/14 04:49 PM
My Duster did that from day one after having the 8 3/4 narrowed, turns out it was bent I ended up using two carpenter squares and measured out 15 inches from the center of the axles off of the axles flanges,no brake drums on the axles, front to back and then top to bottom My new cut down truck Dana 60 had the new ends welded on crooked also There on there square now The car pushes so much easier nowit is almost impossible to tell you the differences Do the basic measureing and go from there
Re: Automatic race car will not roll easily- trans issue? [Re: Cab_Burge] #1612763
04/29/14 06:25 PM
04/29/14 06:25 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have a full width 8 3/4 in the car. If it is bent it was like that from the day I bought it cause it has been like that. I will be pulling it apart in the next couple weeks I will have to check it out.
Re: Automatic race car will not roll easily- trans issue? [Re: dragram440] #1612764
04/29/14 07:03 PM
04/29/14 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does it have a back brace... the OP the drive shaft
was disconnected and the rear rolled fine... a simple
way to check the diff is to pull both axles.. if they
pull out and slide back in easy the tubes arent bent
enough to worry about YET... but ANY car that hooks
CAN bend the tubes and they WILL be bent forward
Re: Automatic race car will not roll easily- trans issue? [Re: MR_P_BODY] #1612765
04/29/14 09:58 PM
04/29/14 09:58 PM
Phila Pa
Phila Pa
Does anyone know how to reduce this drag?
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612766
04/30/14 01:11 AM
04/30/14 01:11 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Put a glide in lol. My car pushes like a dream now...
Re: Automatic race car will not roll easily- trans issue? [Re: scatpacktom] #1612767
04/30/14 02:38 PM
04/30/14 02:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
On a Torqueflight.....No, pretty much is what it is. You could go the super lightweight internals route and all roller bearing, which will help, but a 3 speed Chrysler trans has significant drag.
On guys talking about the car pushing VERY hard.....the reason is, your rear housing is bent. Because it is factory does NOT mean it isn't bent.......as a matter of fact, that pretty much guarantees that it IS bent. Never, repeat NEVER seen a factory housing that was anywhere near straight enough for a race car application. And if you have an 8.75 under something with just average power and it hooks..........you better have significant bracing on the housing, because it WILL bend very easily
Monte
