Hello. Thanks for trusting our products. Here is the link.
http://chucker54.stores.yahoo.net/maravaadeldi.html-Fits Big Block Mopar "RB" Engine 413/426W/440 & 426 Hemi
-Vacuum & Mechanical Advance
MANCINI RACING, Firecore HP distributors use the stock style plug wires and have the correct electrical connector for use with the Mopar wiring harness. Ideal for use with the Mopar electronic ignition conversion kit with the Orange or Chrome ignition box.
Distributor Features:
Fully Machined Forged Housing for a Billet Look
Center-Less Ground Polished Distributor Shaft
Sealed Ball-Bearings - Both Top & Bottom
Adjustable Vacuum & Mechanical Advance
Stock Style Cap & Rotor
Mopar 2-Wire Electrical Connector
Direct Replacement for Mopar Vacuum Advance Distributors & Electronic Ignition Conversion Kits
Smaller Housing than Most HP Distributors - for Extra Clearance to the Cylinder Head & Valve Cover on Big Block & Hemi Engines.
