Re: who stocks wire harness's besides year one?
[Re: ogopogo]
#1612264
04/26/14 01:51 PM
04/26/14 01:51 PM
Posts: 3,691 MO
cdp
MO
[Re: Baller]
#1612268
04/26/14 04:16 PM
04/26/14 04:16 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
http://www.wiringharness.com
Those seem to be the best harness, but you can only buy them through year one.
I'd stick with Year One on this one. BTW, over the last month or so, YO has had 25-30% off coupon codes. I keep getting them via email every couple days..
Or, send your harness to JS Restorations....look under Mopar Extras for more information on JS and YO.
[Re: 1972CudaV21]
#1612269
04/26/14 06:26 PM
04/26/14 06:26 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have noticed that Year One has very rarely offered discounts on wiring (be sure to read what items are exempt when you get discount coupons) likely because they have an exclusive on M&H Harnesses and they don't "need" to discount them.
If you have a decent original harness I'd send it to JS Restorations, he does superb work!
[Re: ScottSmith_Harms]
#1612271
04/26/14 06:48 PM
04/26/14 06:48 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
m&h builds the harness for year one !! on the original wire jigs from the 60,S year one owns the jigs and the rights!! all the connectors r exact copies of oem ones !! top quality ! I have only had problems with the ones with updated electronic ignition option !! there support after the sale from (year one) of course is the best in the bizz !! EXCELLENT PEOPLE TO DEAL WITH
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: Tropicalcats]
#1612274
04/26/14 07:20 PM
04/26/14 07:20 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I got all my harnesses from YO they supply the M&H harness which is probably the best. The only harness I did not get from them is my dash harness which Jim from JS restorations is doing. That's to keep it accurate since the M&H dash harness is not spot on for the 70
Me too! I also agree that M&H is HANDS DOWN the only company to order a harness from.
That said, perfect they are not! Don't drink the "every part is exact", factory correct, etc. Kool-Aid because it isn't in most cases. Wire color (shades) vary a ton, some connectors are unique and unavailable so substitutes are used, and lengths of wires can vary as compared to production line originals regardless of which wire looms they use.
#1612276
04/27/14 01:44 PM
04/27/14 01:44 PM
1972CudaV21
Connecticut
I went to Year One. My current "ROAD14" gives you 25% off the harnesses. Get them while you can. The code is good through tomorrow. Though I'm sure I'll get another one this week..
[Re: AAR#2]
#1612277
04/27/14 01:49 PM
04/27/14 01:49 PM
1972CudaV21
Connecticut
Once purchased through year one and received, I compared the two harnesses, made a power point noting the differences and sent it to M&H. They were first rate dealing with discrepancies, offered to make a new harness to match mine if I sent both harnesses to them, and I did. Any connector they didn't have they used the one from my original. Great experiance and the harness is beautiful !
Good deal if you have a few weeks to wait
PowerPoint? You don't mess around...lol. You really had a great experience with them! Did you have to go through YO or did you contact them directly?
[Re: wesgtx440]
#1612281
04/28/14 07:41 PM
04/28/14 07:41 PM
Posts: 21,501 It's a dry heat
gtx6970
It's a dry heat
So do and other suppliers get their harnesses from Year One?
Yes.
Year one has a wholesale vendor pricing program
