TA / AAR ROCKER OPTIONS??? #1612210
04/26/14 03:09 AM
04/26/14 03:09 AM
canada
lrtexpress Offline OP
canada
Guys Resto is moving along on my AAR, nearing assembly time for the motor, in need of rockers so if any has a set for sale would be great to hear from you, what are other options out there other than originals?
Thanks Dave
Re: TA / AAR ROCKER OPTIONS??? [Re: lrtexpress] #1612211
04/26/14 03:29 AM
04/26/14 03:29 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
outside of original adjustable rockers...
harland sharp makes an aluminum version for the TA head...
http://www.harlandsharp.com/sb_mopar_we-ta.htm
you dont want econo w2 rockers either...they have a larger offset on the intakes..
Re: TA / AAR ROCKER OPTIONS??? [Re: 70AARcuda] #1612212
04/26/14 03:43 AM
04/26/14 03:43 AM
canada
canada
Thanks for the lead, do you know if any clearance issues with stock valve covers?
Re: TA / AAR ROCKER OPTIONS??? [Re: lrtexpress] #1612213
04/26/14 01:46 PM
04/26/14 01:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There was a guy in the wiw section that found a complete set of NOS units and he might want to sell them
I'm pretty sure you could get them for less than the 800-1000 for a set of HS rockers.
Gus
64 Plymouth Savoy
Dana 60
Re: TA / AAR ROCKER OPTIONS??? [Re: lrtexpress] #1612214
04/26/14 04:18 PM
04/26/14 04:18 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
I used the Harlan Sharp rockers on my T/A and two sets of valve cover gaskets to give me a little extra clearance so I could use the original valve covers.
B5 Challenger T/A
Re: TA / AAR ROCKER OPTIONS??? [Re: fourgearsavoy] #1612215
04/27/14 01:55 AM
04/27/14 01:55 AM
canada
canada
Thanks Gus, you referring to the ebay / racing junk / classified section?
Re: TA / AAR ROCKER OPTIONS??? [Re: 70AARcuda] #1612216
04/27/14 01:59 AM
04/27/14 01:59 AM
canada
canada
Being a roller rocker what do you think performance gain is, know lots of variables based on engine build .
