Transmission slip yoke clearance #1611655
04/24/14 09:26 PM
04/24/14 09:26 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
What's the MINIMUM distance of slip yoke clearance (pulling rear ujoint out of rear yoke) that is acceptable? I went to cal-tracs and I don't have a lot of clearance and can't find this info listed in any of my manuals. Thanks Dave
Re: Transmission slip yoke clearance [Re: 3ddart] #1611656
04/24/14 09:44 PM
04/24/14 09:44 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
3/4" of an inch
Re: Transmission slip yoke clearance [Re: 3ddart] #1611657
04/25/14 01:48 AM
04/25/14 01:48 AM
Put two to three hundred lbs. in the trunk and see how much clearance you have then, if it is 1/2 inch or more I would run it on a drag car Not on a street and strip car though 3/4 inch or more for the street
Re: Transmission slip yoke clearance [Re: Cab_Burge] #1611658
04/25/14 10:37 PM
04/25/14 10:37 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
Cab what if cars has ladder bar suspenion? I can get driveshaft out with weight on rear of car. Thanks Bradley
Re: Transmission slip yoke clearance [Re: roadrunnerreds] #1611659
04/25/14 11:03 PM
04/25/14 11:03 PM
Same thing on the rear suspension with ladder bars Make sure , if it has adjustable rear srping mounts, that it is as low as it can be adjusted to before adding the weight
Re: Transmission slip yoke clearance [Re: Cab_Burge] #1611660
04/25/14 11:14 PM
04/25/14 11:14 PM
Gettysburg Pa
Gettysburg Pa
I had an issue where at 85 to about 100 mph i had a vibration in my car. I changed driveshafts checked pinion angle changed trany mounts same thing. Changed pinion yoke from cast yoke to strange yoke and problem solved. Strange yoke is 1/2 longer than cast yoke. I drive it on street sometimes. I was told by another member 3/4 of an inch was good.
