Re: 440 - Eddy 750 - Stumble but rich and not lean
[Re: Steve Bryant]
#1611371
04/24/14 11:55 AM
04/24/14 11:55 AM
RapidRobert
As you know that eddy 750 may be one of the problematic ones, maybe maybe not and that some eddys have a problem on the idle circuit when running a wild cam. I'm assuming the float levels/psi are OK (not over 5.5). I would bump the timing up to 18-20 & if that stands you can shorten the slots later. Yes you'd want the "cruise" step or a smaller jet (which as you know the jet will change power and cruise) to be giving you a leaner mixture & iirc WOT to be ~12.5. I'd get the idle sorted out first. I ain't giving you much here to work with but it's a BTT for ya to get things started. PS you want the curve to start ~200 RPM above your in gear idle speed. You want the carb in the ballpark then fine tune the timing then fine tune the carb
[Re: Steve Bryant]
#1611373
04/24/14 12:18 PM
04/24/14 12:18 PM
RapidRobert
I would get the float/psi out of the way then (1) bump the initial & get it to idle then (2) get the interstate high vacuum cruise ratio correct (I forgot what eBerg recommended) then I ain't sure if you go to the secondaries then come back to the power/AP or if you work on the power/accel pump then the secondaries. You can do it! Maybe this will motivate me to get that bung welded in for my innovate meter. EDIT I believe you dial in the secondarys last
[Re: RapidRobert]
#1611374
04/24/14 12:41 PM
04/24/14 12:41 PM
Posts: 5,167 CT
GTX MATT
CT
So its where you want WOT at cruise and its where you want cruise at WOT...
[Re: Steve Bryant]
#1611377
04/24/14 02:20 PM
04/24/14 02:20 PM
RapidRobert
Rick Ehrenberg the Mopar Action editor who has forgotten/misplaced more info than I will ever know posted some ideal A/F ratios to shoot for. the interstate reference was that you would be at a steady RPM/high vacuum/minimum throttle position out on an interstate drive & would be on the "cruise" step of the rod
[Re: Mr.Yuck]
#1611378
04/24/14 02:32 PM
04/24/14 02:32 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Mopar box will be fine, however I'm not a fan of that eddy carb. If you mush use an Eddy carb go get a 800 thunder.
Mopar box is fine till you hit 4000 rpm , mopar still thinks everyone is using distributors with 34 degrees of mechanical advance .
[Re: Cab_Burge]
#1611381
04/24/14 03:11 PM
04/24/14 03:11 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
INTERESTING ![](/ubbthreads/images/graemlins/thumbs.gif) I too noticed black smoke (over rich) at the tail pipes and a bog/stumble from start on med/hard acceleration. Everyone always say lean/poor accelerator pump issues. ![](/ubbthreads/images/graemlins/drinking.gif) stock +/- 383 727 '67 B Eddy #1407 Still with points and condenser.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Steve Bryant]
#1611386
04/26/14 01:10 AM
04/26/14 01:10 AM
RapidRobert
You have the psi reduced. The floats set (7/16"). a reasonable amount of initial & it's idling at an acceptable RPM. I'd get the cruise set next. I found some notes not sure where from "12.5-13 for WOT. 14 at idle. 14.5-15.5 at cruise". From Eberg: 12.5-13 at WOT. cruise-14.7-15
[Re: Steve Bryant]
#1611388
04/26/14 05:06 AM
04/26/14 05:06 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Check the rod springs might be too heavy or light.Rods should move at the hit of the throttle.
Leave the gun.......take the Cannoli's....Mike
