540 Short block Questions
#1611124
04/23/14 06:55 PM
04/23/14 06:55 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
I found a pretty good deal on a 540 short block in town and I have some questions. It would be going in to my 69 Bee street car with an occasional trip to the track. It is a 440 source kit, in a 1974 440 block. The block has been machined, bores notched and assembled. I was planning on doing a 489 stroker out of a 383 I have and this is a bit more than I was looking for, but the price is right. I figured that with something this size I can get my car to do what I want without pushing it to hard. Is the 540 a good combo and what potential issues is there with running a crank that big in a stock block ? I know I will need an external pick up oil system. Thanks for any input you may have.
1969 Super Bee High School car I got back
2004 Ram 2500
Re: 540 Short block Questions
[Re: Airwoofer]
#1611126
04/23/14 07:36 PM
04/23/14 07:36 PM
runnerrt
Lakewood, Colorado
I don't know. It is on my list of things that might be a good idea.
2004 Ram 2500
[Re: runnerrt]
#1611127
04/23/14 07:51 PM
04/23/14 07:51 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
With a set of 440-1 or 572-13 heads the 540 will make you a good Street/Strip engine.If you do not wish to spend Big $$$ in a cam call Doug Herbert and get you a small roller camshaft & lifters for about the same price as a Hydraulic camshaft & lifters.They are a all around better camshaft they make more power and sound better than a hydraulic cam.And best of all they are very Street friendly. PS If I had not use them myself I would not tell you this!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: runnerrt]
#1611129
04/24/14 09:02 AM
04/24/14 09:02 AM
Posts: 10,023 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I built a stock block 535 (4.350 bore 4.5 stroke) years ago and with ported 906 heads it was a torque animal. Expect the power with stock size ports to be all done by 5000 to 5800 or so depending on cam. You won't have to rev this motor much to get the power due to its size. If the pistons and rods are fairly light, and the tuneup keeps the motor out of detonation at all times it should live a long life.
[Re: Airwoofer]
#1611132
04/26/14 04:54 PM
04/26/14 04:54 PM
runnerrt
Lakewood, Colorado
Well I bought it. I could not pass it up for the price. I will need to check with 440 source on the pin height on the pistons as I may go with a 4.25 stroke and make it a 512, if that would be a little easier on the bottom end. Or I may just sell it and do the 489/496 low deck and save on buying all of the additional parts. Thanks for the info so far.
2004 Ram 2500
[Re: runnerrt]
#1611133
05/02/14 05:17 PM
05/02/14 05:17 PM
runnerrt
Lakewood, Colorado
It looks like I am going to run with this. From what I was able to find here, it sounds like aluminum main caps and a girdle,keep it out of detonation and under 6000 rpm will all help it live. Would a short fill of the water jackets be overkill or added insurance ? I am going to use my MP aluminum 452 from my 383 on it with some port work, so the under 6000 should not be a problem. I am just trying to get me Bee into the mid to upper 11's. I don't think I will need to work it to hard to get there. It is mostly a street car and will only see about 10 to 15 passes a year. Any other advice/tips on this would be a great help. Thanks for everything so far.
2004 Ram 2500
[Re: runnerrt]
#1611134
05/02/14 05:32 PM
05/02/14 05:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt waste my time with a short fill... it only add heat on a street car... just keep the revs down and a good tune on it... try to keep the compression down so you can burn regular and run premium at the track ![](/ubbthreads/images/graemlins/wave.gif)
[Re: runnerrt]
#1611135
05/02/14 05:53 PM
05/02/14 05:53 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
How much compression? 540 with those heads is going to be out of breath at 5000 so just put it in drive so it shifts at 4800 and let the torque be with you. ![](/ubbthreads/images/graemlins/thumbs.gif) With a fairly tight converter it should hit your ET goals with 3.23's. I would spend some of that girdle and cap money inspecting the PO's engine building skills to make sure I got what I payed for and then spend the rest on the chassis. After you get it to hook you can start saving for drivetrain parts. ![](/ubbthreads/images/graemlins/laugh2.gif) Kevin
[Re: Twostick]
#1611136
05/02/14 06:01 PM
05/02/14 06:01 PM
runnerrt
Lakewood, Colorado
According to the 440 source site it is 13 to 1 with the 84 cc chambers. Its a 4 speed car so shifting will all be on me. I will be sending it to be checked out. Since it will be at the shop anyway I will get the caps and get it line bored as well. I am all ready planning for a Dana and new trans.
2004 Ram 2500
[Re: runnerrt]
#1611137
05/02/14 06:13 PM
05/02/14 06:13 PM
MR_P_BODY
Myself... I would talk to your engine shop about changing the pistons... why spend all that money on fuel for a street car... maybe you can sell off the pistons to help out... but no way would I spend money for race fuel on the street ![](/ubbthreads/images/graemlins/wave.gif)
