Difference between 70 and 71 E body Dash harness? #1610726
04/22/14 08:15 PM
04/22/14 08:15 PM
Elk Grove, CA
challngr08 Offline OP
Elk Grove, CA
I need a dash harness for my 70 challenger. Friend will give me one for a 1971 challenger. What is the difference, and can I run a 71 dash harness? Not worried about correct or OE restoration. Thanks guys!
Re: Difference between 70 and 71 E body Dash harness? [Re: challngr08] #1610727
04/22/14 11:53 PM
04/22/14 11:53 PM
Elk Grove, CA
Elk Grove, CA
Surely, somebody knows the difference?
Re: Difference between 70 and 71 E body Dash harness? [Re: challngr08] #1610728
04/23/14 09:24 AM
04/23/14 09:24 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't think there is any difference between 70 and 71? You surely can use it, go for it.
Re: Difference between 70 and 71 E body Dash harness? [Re: challngr08] #1610729
04/23/14 12:47 PM
04/23/14 12:47 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I agree you could probably interchange the two. I'm sure there's minor differences, although nothing that would fry anything. If you're really worried about it, you could compare the wiring diagrams in both the FSMs. There's a few dozen wires, photocopy both diagrams and mark off each wire with a highlighter. It shouldn't be that bad. Good luck.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Difference between 70 and 71 E body Dash harness? [Re: Hrtbkr] #1610730
04/23/14 02:30 PM
04/23/14 02:30 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
Just look at the wiper switch plug. If both cars have a two speed wiper motor or both have a vaiable speed wiper motor than you are OK if the wiper motor and harness are diffiferent then you will need a wiring diagram to correct the situation. In otherwords:
The harness is different if you have a two speed wiper motor or a variable speed motor.
Re: Difference between 70 and 71 E body Dash harness? [Re: Rustydog] #1610731
04/24/14 02:16 PM
04/24/14 02:16 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
It makes a difference if you have a ralley dash or not. In either case you can work through the differences. Look for oil pressure gauge rather than oil light and clock leads and tach leads. Get a wiring diagram. You'll be OK.
